20 Most Recent
Kenmore 73952 Gas Dryer Questions & Answers
My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
Dryer won't start
capacitors are generally located quite close to the motor, and are easily changed, once you have gained access to the inside of the machine, that i can not help you with, it does sound like a capacitor but it could have also damaged the motor by trying to run it repeatedly, stop trying to use the appliance and change the capacitor, change with one the right size only,
work with safety remove plug when working on appliances, if i have helped rate me please
How do I clean the lint from my Model #110.72952100 gas dryer
Hello Bob;
My name is Peter. I am a retired field service appliance technician.
I assume you are not referring to the lint filter on the top of your dryer.
Behind your dryer is a elongated hot air distribution manifold. Looking from the back of your dryer it is on the left. The manifold is fixed to the back of the dryer with screws. Unscrew the screws and remove the cover.
In the bottom of this manifold is where air flow blockage occurs. Clean this inlet out.
At this location you will not be exposed to any electrical or moving parts.
Cleaning this outlet will enhance the dryer air flow and dryer performance.
My Kenmore gas dryer starts but does not stay on
This is very likely a relay problem. There is a black relay in the control head that engages when the start button is pressed. The relays tend to go bad now and then. They are a simple replacement and cost less than $15 or so.
