20 Most Recent KitchenAid Artisan 5KES100 Espresso Maker - red Questions & Answers
Swapping a new boiler as old one stopped heating, I checked both fuses and they were ok
Check the elements, there are 2 on the steam boiler, if 1 is open then that stops them. If your boiler comes complete that's fine, if you just get the element part then you must replace all the seals. I replace the seals on a new boiler anyway, originals are silicone and I upgrade to viton seals. Large one at the bottom, 3 small ones on side of base and one finger sized one at top steam pipe. Check switches for operation, sometimes they stick, if CRC does not fix them then replace. Make sure steam tap shuts off properly. The group head seal goes hard over time, replace while you are working on it if it is. Check thermostat has continuity when cold, on the side at the back of the boiler.
2/21/2015 10:10:49 AM • KitchenAid... • Answered on Feb 21, 2015
Machine makes a knocking sound
The pump probably has air in it, open the steam valve and pump it through.
12/3/2013 6:38:31 AM • KitchenAid... • Answered on Dec 03, 2013
Coffee pot has a salty, chemical smell.
Isopropol Alcohol is the wrong product for that issue. It is a pure alcohol solvent. I have two ideas, and the smell is probably from having water sitting in it an eventually drying out and fusing to limescale. I descale my machine every 6 months. I use CLR. https://www.google.com/search?q=kitchenaid+coffee+machine+descale CLR https://www.google.com/search?q=clr+coffee+maker The other product you might try is 5% Hydrogen Peroxide which is a non toxic, organic bleach. https://www.google.com/search?q=hydrogen+peroxide+to+clean+coffee+maker ..
12/6/2022 5:46:38 AM • KitchenAid... • Answered on Dec 06, 2022
2answers
Hi, I have a Kitchenaid 5KES100 espresso maker. It's making a loud noise and no water is coming through. Any help welcome.
The "percollator" column has become dislodged from the heating element. You may be able to see the tube in the water tank and move it back over the heating element. If you can't understand this info, then it is not for you to do it yourself.
5/26/2021 12:54:10 AM • KitchenAid... • Answered on May 26, 2021
Is there a way to reset a KitchenAid KCM1204 back to factory settings?
You will need to investigate the reason that it's not heating. Check the element and the thermal fuse that should be on the element for continuity. If the fuse has failed replace it and try it again. If the element has failed you may be looking at buying a new coffeemaker.
11/2/2019 5:44:05 PM • KitchenAid... • Answered on Nov 02, 2019
I Have a KitchenAid coffee machine model 5KES0503. There is more water running into the drip tray from the capsule area than out through the spout into the cup. Tried descaling no improvement
Probably the device has calcium built up in it. Do a proper flushing round of at least 500ML (around 15 flushings) or do the "Decalcify" program with the needed tablet for the machine.
10/10/2019 3:08:19 PM • KitchenAid... • Answered on Oct 10, 2019
I have a KitchenAid KCM1402QG coffee maker and even right after running it through a cleaning cycle, the cleaning indicator comes on. Why so often?
Either the scale has not been removed or the sensing circuit has failed. From Kitchenaid, signs a coffee maker needs cleaned; 1, Cleaning indicator light comes on (select models) 2. Excessive brew times 3. Gurgling or other unusual noises during the brew cycle. So ignoring first condition, does it exhibit either of the remaining two? If yes, then likely remaining scale. Try letting descaling agent set, up to max period stated by mfg, then start clean cycle. If no, possible sense failure.
2/8/2019 6:32:29 PM • KitchenAid... • Answered on Feb 08, 2019
I love the kitchenaid coffee pot. after about 6 months, the water pours out of the bottom of the reservoir when filling it. So, I buy another one. Then after about 6 months, it happens again.
Leaking water from bottom of unit during brewing:
  • Verify that the water is leaking from the bottom of the coffee maker and not just running down the back during filling and pooling underneath. (Look under coffee maker - without lifting - to see if water droplets are hanging from bottom of unit)
Resolution: If verified that water is leaking from bottom of coffee maker Contact Us for further assistance. https://www.kitchenaid.com/service-and-support.html
1/30/2019 1:14:55 AM • KitchenAid... • Answered on Jan 30, 2019
KitchenAid coffee maker shows ERR 1. Won’t start dripping
There is a blockage in the drip tray or inside the cavity where your coffee goes, give it a good clean out
4/4/2018 2:20:48 PM • KitchenAid... • Answered on Apr 04, 2018
HI I have a Kitchenaid artisan espresso machine it makes a very load noise when I press the buttons for coffee and froth any suggestions ? thank you
You don't say if there is any water flowing along with the loud noise. If there is none then my suggestion would be that it's a dry water pump so you will need to force some water up the clear pickup tube into the pump while it's making that loud noise. The pump valves will be dry.
11/24/2017 8:13:44 AM • KitchenAid... • Answered on Nov 24, 2017
My new kitchenaid coffee maker leaks when I add water
Shame we don't know what model you are talking about.
9/7/2017 1:06:06 AM • KitchenAid... • Answered on Sep 07, 2017
The blue power on light does not light up when pressed on my Kitchenaid KES100 espresso machine although the high pressure pump runs when the button is pressed. Neither boiler heats up.
You will need to test for where the power stops & check the fuses on each boiler for continuity. If you find any blown then replace the thermostat on that boiler along with the fuses. The thermostats are different rating for each boiler, don't mix them up. It's highly unusual for both boilers to fail at the same time. Occasionally one of the boiler elements can fail, there are 2 elements on each boiler, check them for continuity. If you have any boiler leaks then replace all the seals on that boiler, the steam one is the one most likely to leak. Buy your own seals using the old ones as samples from someone specialising in O ring supply. There are 5 seals on each boiler. Do not purchase rubber or silicone seals, only use Viton seals, they are high temperature.
5/2/2017 7:48:17 PM • KitchenAid... • Answered on May 02, 2017
My Kitchenaid 5kes100 espressomachine won't heat up the steam boiler.
You need to replace the boiler top that includes the elements. When one element has failed the other one stops as well if it is included in the circuit, it's the same as having a broken wire.
4/2/2017 8:01:34 PM • KitchenAid... • Answered on Apr 02, 2017
KitchenAid PRO LINE KPES100PM Espresso Machine- Steam Boiler does not heat up.
Test each element for the correct resistance. Check the thermal fuses for a circuit, they are held onto the top of the boiler with a screw down bracket. Check for a circuit through the thermostat.
2/2/2017 6:26:22 AM • KitchenAid... • Answered on Feb 02, 2017
KitchenAid Artisan 5KES100 Espresso Maker - red Logo
Popular Tags
3 questions posted
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Coffee Makers & Espresso...
  • KitchenAid Coffee Makers & Espresso...
Most Popular Question
swapping new boiler as old one stopped
  • Coffee Makers & Espresso Machines
