20 Most Recent
Kenmore 8000 BTU Single Room Air Conditioner Questions & Answers
OuVery dissapointed and unhappy.
This is a 120volt unit,so I assume it is not the ac unit,try another plug in,in the house,and have the circuit checked that the ac unit was plugged into,there is not enough voltage most likely.
Thank you. I have an 11 year old Kenmore 8000 BTU
take it to a hvac shop and tell them what you want! or just telll an electrical shop what you want in the cord length---to straighten out the fins n the front coils with a fin coil brush at a hvac supply house,and remove the top/ side cover and fully clean the inside unit, drain lines--both front and back coils---on both sidesan oil the fan motor....TYVM!
I have a single room 8000 btu kennmore air
sounds like the compressor may have died on you. the compressor isnt running you might as well trash it sorry for the bad news but it probably isnt worth trying to replace a compressor in a system like that it would drive you crazy and take forever if it could even be done.
Kenmore Model 970-438321
Without a serial number you cannot look up on line what the unit age is. Have you cleaned the condenser coils on the bottom and back of unit?
