20 Most Recent Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 13541 Questions & Answers
2answers
Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
10/16/2018 6:52:31 PM • Kenmore 14.8 cu.... • Answered on Oct 16, 2018
Power to house shut off, now the freezer wont turn on
http://www.appliancepartspros.com/repair-help/ I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
1/2/2018 2:21:09 PM • Kenmore 14.8 cu.... • Answered on Jan 02, 2018
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
10/23/2017 12:42:23 PM • Kenmore 14.8 cu.... • Answered on Oct 23, 2017
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
5/11/2014 3:58:24 PM • Kenmore 14.8 cu.... • Answered on May 11, 2014
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
4/26/2014 12:21:59 PM • Kenmore 14.8 cu.... • Answered on Apr 26, 2014
Freezer reads off on display
Not sure if its the same for all Kenmore freezer models but this may indicate it is in demo mode. To remove this press the up or down arrow three times as fast as possible (within 2 seconds). This will start the compressor, I hope this helps.
1/9/2014 11:42:50 PM • Kenmore 14.8 cu.... • Answered on Jan 09, 2014
Display reads off
There may be a child lock enabled, refer to the owner's manual to disable this feature, otherwise check the troubleshooting section of the manual.
12/22/2013 7:06:07 PM • Kenmore 14.8 cu.... • Answered on Dec 22, 2013
HI i just bought a
No, it's supposed to be hot on its outside: just make sure the airflow around it is good, the compressor and the radiator at the back are clean and the power plug has a good grounding and a proper fuse and all will be OK.
In the worst case scenario you have a malfunctioning defrost resistance that is constantly on and when it will fry it will take the compressor with it, killing the freezer. But only it, the rest of the house and yourself are perfectly fine. If you want to prevent that you will have to dismantle the freezer and disconnect the resistance - without it the ice buildup inside it will be much faster so you will have to stop the freezer for deicing sooner than normal.
9/16/2011 5:39:13 AM • Kenmore 14.8 cu.... • Answered on Sep 16, 2011
Can I put my freezer
YES you can i would put down one of those plastic thing though that you use at the office and roll the chair around on,first to protect the carpet from potential drips and rust stains
8/13/2011 1:24:11 AM • Kenmore 14.8 cu.... • Answered on Aug 13, 2011
Has power but does not freeze
About the only things that can be replaced on a chest style freezer are the thermostat, and the starting device for the compressor. if you know where the control is then thump it fairly hard to see if the unit comes on. If unit comes on then you need to replace the thermostat. (control and thermostat are same thing). now if it has the digital display on the door of the freezer do not thump it. Only the newer freezers have those though. Hope this helps
3/5/2011 4:28:29 PM • Kenmore 14.8 cu.... • Answered on Mar 05, 2011
Is it okay to put
yes it is as long as its not shag or long haired carpeting.
2/21/2011 1:57:23 AM • Kenmore 14.8 cu.... • Answered on Feb 21, 2011
Where is the drain plug
Most freezer do not have a drain plug...it is very possible that you do not have one on yours...
The best way to get the water out is to siphon with a small hose till there is not much left .... then wipe out the rest with a rag....
Tipping the freezer to one corner will help you siphon more of the water out...
heatman101
10/30/2010 5:26:22 PM • Kenmore 14.8 cu.... • Answered on Oct 30, 2010
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 13541 Logo
Popular Tags
58 questions posted
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
ice inside walls chest freezer
  • Freezers
