20 Most Recent
Microsoft Windows Media Player Questions & Answers
WINDOWS MEDIA CODECS
windows media players seem to have a prob. with having all the codec you might need to play a movie. ...even after you install more codec. ....go to the site for VLC media player and download it and you it as a default player. ....vlc media player has all the codec's in it that you would ever come accross. ....works great for me and has never found a movie it could not play
2/10/2022 5:48:38 AM •
Microsoft...
Answered
on Feb 10, 2022
When i download a youtube
You need the Adobe Flash Codec for Windows Media Player. You can get it
here.Alternatively, you can download and install VLC Media Player
here. It plays everything without having muck about with installing various codecs.
1/12/2022 3:26:59 AM •
Microsoft...
Answered
on Jan 12, 2022
BEWARE JANE THE SERIAL SPAMMER BELOW...
Try right clicking the file your trying to play go to properties click change next to opens with then select windows media player see if it will re-associate the files.
don't forget to give testimonial and the votes 4 thumbs up if I helped.
9/2/2020 12:10:09 PM •
Microsoft...
Answered
on Sep 02, 2020
That the windows media player is unable to paly
You need CODECS for some DIVX files.
Use other media players like Media Player Classic instead.
Download from the following link
http://www.free-codecs.com/download/K_lite_codec_pack.htm
7/25/2020 9:47:26 AM •
Microsoft...
Answered
on Jul 25, 2020
Windows Media Player 10
You can not play WMV or ASF media on a website with Internet Explorer's Media Bar turned on.
Internet Explorer has its own player for the Media Bar. To get around the c00d11cd error being generated you need to turn the Media Bar off. To disable Internet Explorer's (version 6) Media Bar click the Media button on the main Toolbar, then click "Media Options" in the new pane that opens. Now select "settings", and then un check "Play web media in the bar".
There is no need to restart your machine as this will take effect immediately.
You have a "playlist" on your PC that you are trying to copy to a CD-R. When you hit the copy button it goes straight to the c00d11cd error!
The most likely cause is DRM. Check the songs on your "playlist" to see if any of the content protected. To do this simply "right click" on each song, then select the "license tab". If any of the songs are protected then you can NOT copy them without the appropriate DRM authority. (DRM = Digital Rights Management) You will need to check with the site you purchased from to see the level of DRM used.
You have a "playlist" on your PC that you are trying to copy to another computer. When you try and play on the new computer it goes straight to the c00d11cd error!
The most likely cause is DRM. (DRM = Digital Rights Management)
It is likely you purchased and downloaded from a site Like Walmart.com Online stores like these set restrictions on what you can do with the .WMA files you download. It is likely that the DRM licence for your download restricts you copying to another PC. You will need to check with the site you purchased from to see the level of DRM used.
You can not copy songs from a CD in the CD drive to your hard disk. Windows Media Player generates the c00d11cd error.
The most likely cause is that something has gone wrong with the special file responsible for the "encoding". The name of the file is: wmadmoe.dll
The first thing we need to do is re-register this file with Windows XP To do this go to the "Start Menu" and select "Run". Now type in the following: regsvr32 wmadmoe.dll
If this does not work then the file itself may be corrupt. To fix this go to the "Start Menu" again and select "Run". Now type in the following: sfc /scannow
This will now scan your XP machine to see if there are any corrupt system files. If there are any then XP will prompt you for the XP CD so it can get a new copy... This may help you resolve the c00d11cd error.
This will get you up and running again, however due to some underlying problems with your installation you may actually need to re-install Windows Media Player.
Please rate this fixya
7/25/2020 8:50:48 AM •
Microsoft...
Answered
on Jul 25, 2020
Windows media player is not playing movies with sound
Need to install the sound driver from the motherboard driver CD.Once installed the sound device will work.Good luck and please do post comments if this does not work, will be glad to help out.Please do rate my solution.
7/25/2020 8:45:09 AM •
Microsoft...
Answered
on Jul 25, 2020
Windows media player non risponde
THE PROBLEM IS EITHER OF THE FILE YOU ARE TRYING TO PLAY WHICH MIGHT BE CORRUPTED OR YOU NEED TO UPGRADE THE PLAYER. TRY PLAYING OTHER DIFFERENT FILES. IF IT RUNS GOOD THEN THE FILE YOU ARE TRYING TO PLAY IS THE CULPRIT.
REGARDS.
PLZ. RATE THIS
7/25/2020 8:37:51 AM •
Microsoft...
Answered
on Jul 25, 2020
The window media player cannot open the
Hi. I think the problem on this issue is that the file that you're trying to play is not supported my your Windows Media Player. You can solve this problem by downloading updates for your media player or the codec packs like K-Lite. Also you can just download another media player like VLC Player, you can download this into google, just type in VLC Player and download and install it on your computer. This VLC players supports almost all video or audio file extension. Goodluck!
7/25/2020 8:32:04 AM •
Microsoft...
Answered
on Jul 25, 2020
Update the media player or reinstall a new copy.
That is the 1st thing that you should try.
Thanks
Smith
7/25/2020 8:24:19 AM •
Microsoft...
Answered
on Jul 25, 2020
