20 Most Recent
Disney Cars 16-Inch Boys BMX Bike Questions & Answers
I am trying to get the hand break attached
there is a screw in adjustment to allow you to install it, screw both ends if they both are adjustable, then you can reattach, after than screw each end back out to adjust. Hope this helps you! and Merry Christmas!
How to fix flat tire on disney princess 16 inch bike
There are a few ways to fix a flat tire.. First I don't recommend that you use Fix-a-Flat due to combustion issues in high heat.. {Step:1}. Go to Walmart or closest bike store and purchase the "Stick on Patch" made by Slime or get the old school patch kit witch i prefer and the patch kit includes, "Patches,Rubber Cement and a Tube Scratcher" {Step:3} take the rim off the bike and then take the tire off the rim by inserting a flat head screw driver careful not to poke the inner tube and use a second screw driver to pop off the tire from the rim and manual pull only one side of tire all the way around tell one side of the tire is off the rim make sure the valve stem cap is off and push the valve stem out and pull out tube.. {Step:3} this is my own special trick know one ever uses Pump the tube up just enough for air to come out of hole. In a sink of water put the tube in the water and were there are bubbles are were a hole is at... Get a Sharpe and mark that spot and dry inner tube and get the scraper from your kit and scratch all around the hole just to scruff it up a little.. {Step:4} Now here is the trick of all tricks... stretch the tube were hole is on the corner of a table not to much though with hole side up and apply a good amount of the rubber glue and light with a lighter and let burn for a few seconds blow it out and repeat one or two more times and then apply the patch """Blue Side Up"" with a roller type of devise roll the patch on to the tube rolling the roller back and forth repeatedly going up,down,sideways pressing firmly on the patch until the plastic on the blue side is coming off. Make sure the patch all the way around loks sealed.. Don't worry you can tell.. then your done.. now reinstall by reversing with out the screw drivers of course and by hand push the tire with your hands all the way around tell tire is on rim... Now you are an expert tire changer and your kids or even friends will get a show out of it due to the fire part.. Hope this helped cause it was a long lesson..Lol
We have misplaced the assembly instructions on our
Getting the exact manual for your bike is not necessary. All bikes are basically the same and the website parktool.com/repair will have instructions on bike assembly that should be sufficient to get your bike together.
Need assemble instructions for girls starlet 12
Try Moorelarge uk on the web, they are the distributors for Bumper.Kids bikes are generic when it comes to instructions,most manuals are the same.Local bike shop probably has instruction books lying around.
Test 18-08
Test received A-OK
What is the problem with your Bicycle?
Water pressure
i take it you are asking about a combi boiler typical pressure 1-2 bar
