20 Most Recent
Topeak Panoram V12 Mini 12 Function Cycle Computer Questions & Answers
Convert kph into mph
1 kph = 0.621371 mph
But if you want to change the way speed is displayed, press the Set button for one second, then press the Mode button for 3 seconds 3 times (or until you get to the kph/mph page) then press the Mode button for one second to change kph to mph.
Where is the correct spot to put the magnet on the
The only placement requirement for the magnet is that it pass exactly next to the sending unit you mount on the fork (there is usually a mark on the unit). So, really the placement of the sending unit determines the "correct" placement of the magnet on the spoke.
I have fitted it hasnt worked. I have the wireless
While off the bike, try spinning the wheel (with the bike supported with the wheel in the air) and move the wheel sensor closer. Be careful not to get your fingers stuck in the spokes. Make sure the sensor lines up correctly. If this doesn't work you may have a defective unit.
How do you reset the trip meter?
there's just one button on this unit if i recall. so just get to the screen where it shows the trip meter, and press and hold the button until it resets.
