20 Most Recent
Kenmore 50522 / 50524 Side by Side Refrigerator Questions & Answers
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
Ice maker in refridgerator freezer won't make ice
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Can refrigerator work if freezer is not in a kemore side by side?
Unfortunately, no. If your freezer is not cooling then your refrigerator side will also get warm. The freezer is the source of cooling and it uses a fan to force the cold air into the refrigerator side. I would suggest calling a repairman to look at it for you to find out if it is fixable. It could just be something simple and does not always mean that you have to replace the unit, but that may be a possibility as well. Sorry!
Ice maker making water
The origional problem was probably not the icemaker but the electronic controller that sends power to the icemaker.
