20 Most Recent
Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267 Questions & Answers
I have a kenmore side by side refigator and with
you might need to open the water pip and clean the volve on the bottom of your fridg. its get clug some time but if its not working then your valve need to be replace..get me your model # i get you the part#...
911servicetoday . com
WHEN THE WATER IS TURNED ON FOR ICE MAKER IT WILL
There are several things this could be. The switch for the lever that turns on the water could be stuck and holding the solenoid on. The other thing could be the water valve could have something stuck in it that is keeping it from shutting off the water. I have taken these apart in the past and found sediment stuck in the valve. Since you say that you have filteration on the line, is the filter installed? If you find a canister looking thing on the water line, often in the basement ceiling, then the likely culprit is the switch.
Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
106.9547610 Kenmore SIde by Side not cool
It looks like you have been having a long conversation about your no cool refrigerator, would you like me to step in an assist or step back and allow the previous tech to continue?
