20 Most Recent
Kenmore 62832 / 62834 / 62839 Bottom Freezer Refrigerator Questions & Answers
I'm not sure which one I have, but purchased my
Cold air from freezer blows into refrigerator compartment right behind that tray. Freezes stuff in that tray. Pizpoor design. Known issue. With GE refrigerators also of same design. That kenmore most likely was build by GE. GE/Kenmore deny the issue but thousands of posts online about it. No solution. Sorry. Good luck.
I have a Kenmore side
Your compressor just went bad...
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
Hello, our freezer is working fine so far but the
The first thing you should be looking for is a frost or "snowy" build up on the back wall of the freezer. Assuming that there is a build up then you need to remove the back wall of the freezer. Gaining access to the defrost thermostat and defrost heater is a little difficult due to the frost build up. the defrost thermostat is attached to the evaporator coils to the right of the fan assembly. You need to check for continuity across the thermostat. The thermostat is the most likely cause.
Our model is freezer on
Hi, these are the possible cause of the problem, you have to check one after the other to proffer the solution.
- Vents between fridge and freezer sections are clogged with ice. Warranty guy told me to unplug 24 hours, replug and everything should work out.
- Fautly thermostat.
- Clogged/dirty evaporator coils (underneath in newer models, on back in older models).
- Bad "Adaptive Defrost Control Board", Google it, it's an easy fix, about $35 on ebay, just make sure you
Frozen water in bottom of freezer
Every ten to twelve hours your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-20oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Kenmore model 66792 bottom freezer
Hi , check at the back if can find small motor the infeller is inside /if small motor hamming infeller inside are full of ice , let the timer rotate manually hear cracking of ice smelling like burning , that the hot coil burning, if does not burning coil has problem.
I can't get my ice maker water filter to turn and lock in place
Put some Vaseline on the O-Ring to help it slide into place. Make sure it is properly inserted at the beginning.
If the filter is located inside the refrigerator:
- Turn off the ice maker.
- Push the eject button.
- Pull the filter out of the housing.
- Push the new filter into the housing until it clicks.
- Turn on the ice maker.
- Run 2 gallons of water through the water dispenser to purge air and residue.
More items...
Aug 30, 2023
1/28/2024 2:40:53 AM •
Kenmore...
Answered
on Jan 28, 2024
