20 Most Recent Kenmore 53502 / 53504 Side by Side Refrigerator Questions & Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Kenmore 53502 /... | Answered on Sep 26, 2011
You could have a bad augar motor. It will turn one way for crush and the other way cube. that is the moldel with ice bin on door. If you have ice bin in the freezer not on the door. you could have the ice crusher lever jammed. that is the wire lever on the bottom of ice bin. Or the selnoid the moves the lever up thus opening the door and allowing the ice to pass the crushers. hope this helps.
Kenmore 53502 /... | Answered on Aug 20, 2011
thaw and it will probably start working.
Kenmore 53502 /... | Answered on Nov 01, 2010
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Kenmore 53502 /... | Answered on Oct 07, 2010
You have a bad relay . Replace the " white box " ( it just pushes onto the compressor ) with maybe a small wire to secure it . Take your complete model number , including the 3 numbers in front of the ones you gave , to make sure you get the correct part .
Kenmore 53502 /... | Answered on Apr 28, 2010
This is still a great refrigerator! Your defrost system has just gone out. Call or email us and we can ship parts next day to you. 972-859-0929
Kenmore 53502 /... | Answered on Sep 28, 2009
Hi, It sounds like the inlet valve needs changes. Could be the plunger inside the solenoid is not lifting to allow water through. If you remove the line going to the ice maker off the inlet valve, try and cycle the ice maker and put the inlet valve over a bucket to see if water is coming out when it gets voltage.
I hope this helps.Please let me knwo if I can assist you further.
Thanks
Vic
Kenmore 53502 /... | Answered on May 31, 2009
try removing the panel in the freezer. you will see an evaporator fan . test it and the thermostat beside it it is one of the two
Kenmore 53502 /... | Answered on Apr 09, 2009
This usually means you have a weeping water valve. The water valve doesn't completely shut down after filling the icemaker. This deposits a staedy flow of water which freezes and accumulates in the tube, eventually blocking it off. You would need to replace the water valve which is located at the rear of the refrigerstor. One othe thing to check would be the water supply to the refrig. If the water dispenser is working fine then that isn't an issue. However, if that is flowing slowly you would need to replace the saddle valve which is tapping into your house water supply.
Hi Slinn. "..... no krinks or leaks...any ideas?"
How about a solution. Would a solution work? ;-)
Your water valve has gone to appliance parts heaven and now, sadly, needs to be replaced. Don't sweat it, though. Even if you've never done it before it'll be a quick 1/2 hour job.
Tools;
1.) 1/4" nut driver or socket
2.) Pliers or 1/2" open end wrench
3.) A dirty towel (to clean up the little bit of water after the repair)
Parts;
1.) Valve (part# 4318046). (It can be purchased at your local appliance parts retailer)
Now for the fun stuff! Pull the fridge out (it's on rollers, just give it a good tug to get it started rolling) far enough so that you can get behind it to work. Turn the water off at the wall.
NOW UNPLUG IT!
(you wouldn't wanna look like this, would you?)
OK, you're behind the fridge, look down and right. You'll see where the water line connects to the fridge (that's actually the old valve there). Remove the water line from the valve with your Pliers or wrench and set aside.
See that cardboard panel on the back? You'll need to remove a few of the screws from the right side... enough screws removed to fold the cardboard back to expose the valve. Now remove the 2 screws that hold the valve on and pull the valve out from the cavity.
Get your new valve and hold it next to the old one and notice how it should be connected (wiring and tubing). Now all that's left is to do is pull the wiring and tubing from the old one and put it on the new one. Re-mount the valve and replace the screws for the cardboard. Now re-install the water line, use the towel to clean up the water and lastly, plug the fridge back into the outlet.
Really quick and easy. You should have no problems with ice after this.
SG
Kenmore 53502 /... | Answered on Mar 23, 2009
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Kenmore 53502 /... | Answered on Feb 28, 2009
If you are sure you have the right start relay, and are positive the start and run connections are correct, the compressor may be bad. There is an internal overload/overheat thermostat inside the compressor. If the motor windings are partially shorted out it will run for a little bit then stop. It will probably start after several hours when cooled down. The other possibility is that you have the start and run terminals reversed. If the start winding can't kick out after a few minutes it will overheat. As a final test, disconnect all wires from compressor. Plug in the box and turn it on. Make a test cord with a plug, wire and some alligator clips. One clip on one side and two clips on the other pole. Single clip goes to the common terminal, One of the other goes to the run. The last one is briefly touched to the run terminal. Just keep it there long enough for the compressor to start then remove it. Let it run for a few hours. It should cool the box down completely. It will run until you stop it as it's not using the thermostat in the box. If it works this way replace the relay again. If it stops by itself the compressor needs to be replaced. This is almost never worth it to fix.
Kenmore 53502 /... | Answered on Jul 03, 2008
This can be a complex problem. Test whether the defrost heater circuit is getting 120 v from the main control board. If it is getting the voltage, the main control board is okay. You could have a broken heating element or a blown fuse in the defrost control assembly. Here's a video for a different error code that shows how to access the freezer evaporator in that type of refrigerator: youtube.com/watch?v=a4MdwuoN3jc Unplug the refrigerator and use the procedure in that video to remove the evaporator cover in the freezer. Check the resistance through the defrost heater and replace it if it's electrical open (measures infinite resistance). If the defrost heater is okay, you may need to replace the defrost control assembly which contains the defrost thermistor and fuse. You might want to call a service person on this.
Kenmore... | Answered 1 hour ago
Kenmore 53502 / 53504 Side by Side Refrigerator Logo
Popular Tags
25 questions posted
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
kenmore 53504300 water floor after
  • Refrigerators
