20 Most Recent
Kenmore 64823 Top Freezer Refrigerator Questions & Answers
I want to change the
Hello and Welcome to FixYa!
What I understand from your query is that you want to alter the door opening direction If I'm right... Altering the door such that it opens on the counter side is possible. but in most cases, it ruins the working of the device completely.. actually changing the direction causes many things to go wild from the refrigerator light switch. to the refrigerator doors gasket. Also it requires some new holes to be drilled at the other side... That turns the alteration to more complex and tricky.. In a nut shell, I would not suggest to have such changes to your equipment.
Have a nice day,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Fridge wont cool.
Refrigerators draw air from the freezer to cool them. There are several
possibilities. First check to see if you need to defrost the freezer, this can cause a blockage stopping the air to the refrigerator also make sure that there is nothing blocking the air flow in the refrigerator.
You can set the
freezer colder and turn up the refrigerator setting dial.
If these don't work it could be the fan that is supposed to circulate the air to the refrigerator is not working. The door switch for the light often turns the fan off while the refrigerator door is open.
If the freezer is all the way up and items in the freezer aren't frozen hard then you most likely need you system recharged or there may be something wrong with the compressor.
How to clean cooling coils
IF YOUR TALKING ABOUT THE CONDENSER COIL ON THE OUTSIDE USED COMPRESSED AIR..A REAL PAIN BECAUSE YOU WILL NEED TO TAKE IT OUT SIDE..EVAP COILS ON INSIDE A LOT EASIER..BUT YOU HAVE TO REMOVE THE PERISHABLES AND TURN OFF UNIT AND OPEN DOORS AND DEFROST...ONCE THE WATER IS REMOVED PLUG IN...RDS
Water Leaking going under my tiles
if the pan was dry it may be that the tube running from the freezer to that pan is plugged with ice. you will need to manually defrost it by either unplugging the fridge or turning the thermostat to off and opening the doors on the fridge and freezer for about 4-5 hours. there will be quite a bit of water that will come out so put some towels down to catch it. after it is done defrosting go ahead and plug it back in this should solve your issue.
Fan not working?
You may have a bad Evaporator Fan Motor. You can check with an ohm meter.
Caution: Please read our safety information Before working on your appliance, unplug the appliance to
avoid an electrical shock hazard.
The evaporator fan is located at the back of the freezer. It will be necessary to remove back inside panel of
the freezer. Remove any screws that secure the back panel. Next remove any screws that secure the fan
or fan housing so that you can access the fan's wiring.
Label the wire placement on the fan before disconnecting the wires. Pull the connector off of the fan's
terminal. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the
connectors for corrosion. If the connectors are corroded they should be cleaned or replaced.
Remove the fan blade from the old motor and place it onto the new fan motor. The Fan blade may slip off
the motor shaft. Or the blade may have a spring or "C" clip. Use a slotted screwdriver to pry off the clip
Replace the fan onto the mounting bracket and back into the fan housing. Spin the fan to make certain it
can turn freely. Replace the rear freezer panel and plug in the appliance.
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
I can't get my ice maker water filter to turn and lock in place
Put some Vaseline on the O-Ring to help it slide into place. Make sure it is properly inserted at the beginning.
If the filter is located inside the refrigerator:
- Turn off the ice maker.
- Push the eject button.
- Pull the filter out of the housing.
- Push the new filter into the housing until it clicks.
- Turn on the ice maker.
- Run 2 gallons of water through the water dispenser to purge air and residue.
More items...
Aug 30, 2023
1/28/2024 2:40:53 AM •
Kenmore...
Answered
on Jan 28, 2024
