20 Most Recent Bubble-magus BM-NAC QQ-220V Hang Inside Protein Skimmer: Hanging Skimm Questions & Answers
Try another wall connection or your wire connection, as well as making sure nothing is wet around the connections, and ultimately nothing is wrong with the entire lighting system.
Fish | Answered on Jan 03, 2020
They come from eggs that were hidden within the aquatic vegetation you placed in the aquarium that your fish use to discharge them away from being viewed or easily reached.
Much too late to help, I'm sure, but the cheapest fix would likely be to add a simple tap switch.When the tap switch is turned off, it cuts the power off and the light will go out. A tap switch is simply an outlet with a switch fitted. Plug the tap switch into the wall, plug the aquarium light into the tap switch and you're set. They're cheap at places like Home Depot, likely half the price of the replacement switch from Hagen, who makes Fluval. Also a great way to make it easy to turn filters on and off without having to pull the cord from the outlet.
Fish | Answered on Dec 26, 2019
"How to assemble? - Fish"???
Umm, you take the body and stick the marked fins on the sides, top, and back at the appropriate slots then install the batteries and drop it in the tank.
Fish | Answered on Dec 25, 2019
That would depend on the plant. Some plants can be transplanted at any time.
Fish | Answered on Dec 03, 2019
Bacteria in fish tank ?
Bacteria is normal . breaks down ammonia from fish into nitrate.
Nitrate is harmful and requires a water change unless you pump the water through plants google aquaponics.
Algae in fish tank ? buy water snails put in tank
Fish | Answered on Oct 22, 2019
I think, a sponge filter is for you - simple, cheap and effective.
It provides mechanical and biological filtration, once the sponge has grown bacterial colonies. Filters come in a variety of sizes shapes, and pore sizes to adapt them to an almost filtration need. Sponges give excellent results in ponds, saltwater, and freshwater. They can be used as an addition to another filter, such as a canister filter, or as the only source of aquarium filtration - https://great-filter.com/best-sponge-filter/
Fish | Answered on Jul 29, 2019
If it connected to a public water course, yes you do.
If it is totally on your land and spring fed, no you don't, as it is fully yours and on private property.
Best thing to do is phone your local Department of Natural Resources.
https://en.wikipedia.org/wiki/Riparian_water_rights
Fish | Answered on Jul 11, 2019
In my opinion, power filters are the best. They are easy to maintain and are also quite economical. The most common style of power filter hangs on the back of your tank. A siphon will pull water from the tank, eliminating any bacteria and returning filtered water back into the aquarium.
Fish | Answered on Jun 21, 2019
Currently looking for an London seo london Agency, due to the fact I at the moment dwell in that place, and have alot of labor inside my portfolio of internet sites.
Fish | Answered on Jun 05, 2019
I believe this is about fishing?
Fish | Answered on Feb 14, 2019
We don't have anything! We are FIXYA dot com, we only supply information.
no they are made in China. YOu can buy bulbs, you can replace light strings if it is a pre-lit tree, but no parts. If it is the base that is the problem, you could buy a live tree base and tighten it right down. The rivet caps on folding arms are available in Home Depot.
Fish | Answered on Jan 06, 2019
yes, but according to future growth size, spaced so as not to be overcrowded as the grow and according to their food availability.
Fish | Answered on Jan 02, 2019
30 gallons of water weighs 300 lb and then there is the weight of the aquarium itself and accessories - that is a lot of weight that is likely to distort even a robust cabinet if it isn't standing on a perfectly flat and level floor, the most common reason why cupboards, cabinets and chests of all sorts never seem as good at home as in the shop.
Another possibility if the unit arrived as a flat pack, perhaps the attention to detail during assembly was less than precise...
Fish | Answered on Jan 01, 2019
Bubble-magus BM-NAC QQ-220V Hang Inside Protein Skimmer: Hanging Skimm Logo
0 questions posted
Top Bubble-magus Fish Experts
Karen J Gray
Karen J Gray
Fahr Quad
Are you a Bubble-magus Fish Expert? Answer questions, earn points and help others
View Most Popular
Bubble-magus Fish
  • Bubble-magus Fish
Most Popular Question
triazicide granules used in green houses
  • Fish
