20 Most Recent
Toto CST414M-11 Aquia Dual Flush Elongated Toilet - Colonial White Questions & Answers
My toile tank does not completly flush, I have to
Sounds like the adjust on the flapper has to much slack on the chain. It's not raising it up enough to flush correctly.
Adjust that and make sure water level in tank is correct at least up to mark in tank or about 5/8" to top of overflow .
Also check fill line and make sure it is connected to overflow also this allows bowl to fill up.
Leak at base
Replace the wax ring between the toilet and flange in the floor drain. Clean out the wax of the old ring very well.
Noise of flush water
You have two issues inside of the toilet tank. The holding down the button is caused by your chain not being tight enough from the handle to the flapper. Take the slack out of that and replace the flapper. The second is that you need to replace the fill valve. This is what is making the noise when the tank is being refilled, and will have to be adjusted after it is installed.
Please remember to rate this.
I have a toto toilet. After flushing it is taking
Make sure that the fill valve doesn't have debris caught inside near the valve needle. Also the tube that attaches onto the flush valve can become clogged near the fill valve as well. Remove the hose and then take a needle and try and clear the outlet. Blow through the tube to insure that it's not blocked as well.
Toto Neorest 600 issue of low water pressure
page 35 of your instructions. Don't have it, here is a link copy and paste
https://www.totousa.com/filemanager_uploads/product_assets/OwnersManual/0GU9001R_NEOREST_600_EN_OM.pdf
7/8/2023 3:46:16 PM •
Toto Home
Answered
on Jul 08, 2023
Toto washlet s300 has developed slow leak from behind brass connection and plastic.
If you are able to identify the source of the leak, you may be able to fix it yourself. If the leak is coming from the brass connection, you may need to replace the connection or tighten it. If the leak is coming from the plastic, you may need to replace the plastic part or use a sealant to stop the leak. If you are unable to identify the source of the leak, it is best to contact a professional plumber to help you diagnose and repair the issue.
3/16/2023 9:59:53 PM •
Toto Home
Answered
on Mar 16, 2023
The stream on "Rear" is weak on my new Toto Washlet GL since I got it 1 week ago. The "Soft Rear" setting works OK, but the normal Rear wash is no stronger than the "Soft" setting.
It sounds like you may have a problem with the water pressure for the rear wash setting on your Toto Washlet. Here are a few things you can try to troubleshoot the issue:
- Make sure that the water supply hoses for your washlet are securely attached and not kinked or clogged.
- Check the water pressure at the source (e.g., the wall outlet or the valve under the sink). If the water pressure is low, that could be the cause of the weak stream.
- If the water pressure is fine, try cleaning the nozzle for the rear wash setting. Sometimes debris can accumulate in the nozzle and cause the stream to be weak.
- If none of these troubleshooting steps help, you may need to contact Toto customer service for further assistance. They should be able to provide you with additional guidance or arrange for a service technician to come and check your washlet.
1/6/2023 8:31:31 PM •
Toto Home
Answered
on Jan 06, 2023
