20 Most Recent
KitchenAid KIRD861HSS Kitchen Hood Questions & Answers
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Downdraft vent won't stay down. Push the button
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Retractable vent stuck
after struggling for hours to remove vent for cleaning, I just happen to pull frong panel forward, and that release the vent so that i could clean it. No big deal. Simple
Hood does not pop up when depressing the push button
The filter elements are mostly likely not correctly in place so the latch is not tripping the micro-switch. Using a flash light this was clear by looking down into the front edge of the vent unit. I could see the element edge and the latch of the filter element. It wasn't latched tight. I used a paint scraper (two). Gently i nserted it while also using a flash light to see. I was able to lever and jiggle the filter element back into place and latch it. This activates the control. Then the unit would raise. I double checked the filter latches to be sure they were tightly closed.
Hello, where can I locate
There should be a 1 or 0 at the end of the model #. Either way it uses the same part #. There have 2 different filters that can be used. One is probably stainless and the other is probably plastic due to the price difference. You can get them at:
http://www.searspartsdirect.com/partsdirect/index.actionType in your model# and select model# for type of search. Depending on your model, it will be #33,33A, or 33B on the drawing.
Hope this helps you out
Happy Holidays
Mr Tin Man
The hood goes up and
If the hood rises and retracts and no blower the problem is most often the motor. Unfortunately the motor does not have reset like disposer.
The motor for your system is part number 4360212 and cost about $350.00 for the part and a reputable company should charge about $150.00 labor to replace it.
How can you manually open the Kitchen Aid KIRD861HSS?
By removing the decorative cover plate you somewhat expose the units inner workings. Carefully, insert a small sharp object into the unit at the point in which the micro-switch(es) are exposed. The micro-switch(es) will appear as small little plastic tabs that are poking out. While simultaneously depressing the power button, insert the sharp object into the micro-switch(es) closing the circuit. The down draft will raise enough to the point in which you can re-seat or install the filter thus making it operational.
