20 Most Recent
American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant Questions & Answers
Leaking at base after flushing
are you sure its the floor connection as it could be the tank one, also if the floor section is there a insert sealed and fitted to the existing floor pipe and then the wax seal around this. similar model video. https://youtu.be/LebANJC2rx4
6/5/2021 12:24:47 PM •
American...
Answered
on Jun 05, 2021
Slow leak from tank into bowl. We can hear tank
I'm contractor for the last 17 years and this is the first
time I have problems with the toilet tank installation , I bought four toilets,
three of them had a leaking tank I thought that the place that had bolt did not
have enough pressure and I put more pressure every five minutes but the toilets
kept on leaking, I took the bolts out and I put plumbing putty in the top and
the bottom and installed it again but it kept on leaking then i removed the
putty and i put liquid teflon on the bolts and finally the leaking stoped.
Edit your post:
To insert a product link use the format:
[[ASIN:ASIN product-title]] (What's this?)
I'm contractor for the last 17 years and this is the first time I have problems with the toilet tank installation , I bought four toilets, three of them had a leaking tank I thought that the place that had bolt did not have enough pressure and I put more pressure every five minutes but the toilets kept on leaking, I took the bolts out and I put plumbing putty in the top and the bottom and installed it again but it kept on leaking then i removed the putty and i put liquid teflon on the bolts and finally the leaking stoped.
Guidelines
12/7/2017 3:06:41 AM •
American...
Answered
on Dec 07, 2017
Is is possible to make a full flush toilet from an
If your toilet is not moving waste all the way to the septic, then there may be a blockage in the waste line or it may not be plumbed correctly. There is no reason why you should not be able to make a full flush on septic. I have live on septic for many years and it should flush as well as living in the city. Is your water supply nice and strong? This sound like a gravity issue with the waste line or a blockage, If you can get under your house and see how the waste line is run, that would be helpful, it should be aimed straight down underneath your toilet and never running uphill at any point on the way to the septic tank. Also is there a vent in the waste line at the proper distance. If not, that could also be the issue. Good luck. P.s. does your septic tank need pumped out?
4/29/2016 6:03:02 AM •
American...
Answered
on Apr 29, 2016
Fix an american standard slow close toilet seat
Check the chain the goes between the handle and the flapper.
It should not be taught. If it is it will not permit the flapper to seat
properly and water will leak out. Adjust the chain length so the flapper is seated and there is just a little slack in the chain.
8/2/2015 7:31:42 PM •
American...
Answered
on Aug 02, 2015
Relace flush valve seal
The American Standard Cadet 3 flowise one piece toilet uses a flapper valve with a soft nylon washer to seal against the water outlet.
Over time this nylon washer develops 'puckers' causing water to seep between the nylon washer and the seat of the flapper. This seepage causes the water level in the tank to drop to a point where the water inlet valve opens to replace the lost water in the tank.
There are two ways to correct this problem:
1. Replace the soft nylon washer on the flapper, or
2. Replace the entire flapper valve.
Hope this solution helps.
7/27/2015 4:59:56 PM •
American...
Answered
on Jul 27, 2015
Toilet tank to bowl small leak
You need to replace the tank to bowl nuts, washers, and gaskets as well as the flush valve gasket. One word of caution. When installing the new bolts to hold the tank in, place a rubber gasket under the washer inside the tank, and also one on each bolt under the washer underneath the tank. If you omit the one under the tank you may end up cracking the tank when you tighten it down.
8/23/2014 7:56:43 PM •
American...
Answered
on Aug 23, 2014
I have a american standard
To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
4/4/2014 1:38:34 AM •
American...
Answered
on Apr 04, 2014
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
11/11/2013 11:58:44 AM •
American...
Answered
on Nov 11, 2013
Toilot does not flush completly
Raise height of water by raising float valve. It has a twist knob at top of ball to raise and lower ball. Column should be about 1 inch below overflow tube.
11/11/2013 11:57:25 AM •
American...
Answered
on Nov 11, 2013
Convert calculator
One inch is exactly 2.54 cm, so if you're 5 ft 9 in then you're about 175 cm.
5/20/2013 9:30:26 PM •
American...
Answered
on May 20, 2013
