20 Most Recent KitchenAid K45SS Classic Stand Mixer Questions & Answers
Hiya,
I am sorry to hear you are having trouble with your mixer.
I have added a link below for our help video on adjusting the speed settings on your KitchenAid mixer:
https://www.youtube.com/watch?v=bM3t46afGcc
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/KitchenAidSpeedSettings/tabid/615/Default.aspx
I hope this helps!!
KitchenAid K45SS... | Answered on Jan 02, 2020
Hiya,
I am sorry to hear you are having problems with your speed on your mixer.
I have added a link below for a help video on adjusting the speed on your mixer:
I hope this helps you solve the problem!
KitchenAid K45SS... | Answered on Nov 20, 2019
Hiya,
I am sorry to hear you are having trouble with your mixer. I have added below a link which is a help video on setting the correct speed on your mixer:
I hope this video helps you to resolve the issue :)
KitchenAid K45SS... | Answered on Oct 30, 2019
Adjust the head height, tilt the head back and look into the hinge area from the front over the top of the bowl. Undo that slottedscrew you can see in the middle of the hinge a quarter turn at a time until it stops scraping.
KitchenAid K45SS... | Answered on Oct 05, 2019
There is a problem in the planetary, there is wear or lack of lubrication causing wear in something in that area. Replacing the planetary is not a big or expensive job.
Hiya,
I am sorry to hear you are having an issue with your machine! To solve this problem, you will need to remove the drip ring from your mixer and give it a good clean, this should stop the grease leaking.
I hope this helps you! :)
KitchenAid K45SS... | Answered on Oct 04, 2019
Hiya,
I am sorry to hear you are having problems with your KitchenAid mixer. It may just be that your motor brushes are worn down or have not been put in correctly. I have added links below for our help videos on replacing the motor brushes and have also added a link if you wish to purchase a new set:
6778011 KABrushSet KitchenAid Mixer Motor Brush Set (2 x W10380496 brushes) https://secure.kaparts.co.uk/sku/6778011
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/KitchenAidMotorBrushReplacement/tabid/597/Default.aspx
https://www.youtube.com/watch?v=5YuS3atXR0M
I hope this helps you solve the issue :)
Hiya,
Please check if your motor brushes have been put in correctly as this may be the issue. I have added links below for our help video on motor brushes which may help you:
I hope this helps you solve the problem! :)
Hiya,
Sorry you are experiencing an issue with your appliance. It would appear you need to replace your phase board. Please see one of the links below to assist you. Please note the videos show how to replace 230V phase board. The steps are the same for 110V. Please make sure you have the correct part for your appliance.
https://www.youtube.com/watch?v=era-Dp5P8Xw
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/KitchenAidReplacingyourphaseboard230volt/tabid/613/Default.aspx
KitchenAid K45SS... | Answered on Sep 27, 2019
Hiya,
Sorry to hear you are experiencing an issue with your appliance.
We have created some videos, that might help you resolve this issue. Please see one of the links below:
Hiya,
Sorry you are experiencing an issue with your appliance. We have some help videos to assist you with resolving this issue. Please see one of the links below for your perusal.
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/Howtoreplacethespeedlever/tabid/643/Default.aspx
https://www.youtube.com/watch?v=y97KT98vpJ0
To purchase new speed lever, please see the below link:
9709276 KitchenAid Tilt Head Stand Mixer Part (also 5qt bowl lift) Speed Lever Black https://secure.kaparts.co.uk/sku/9709276
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
KitchenAid K45SS... | Answered on May 12, 2019
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
KitchenAid K45SS... | Answered on Nov 08, 2018
You can download a copy of the owner's manual for the K45SS stand mixer
at Kitchenaid.com (SUPPORT>LOCATE MANUALS & GUIDES)
KitchenAid K45SS... | Answered on May 07, 2018
Are you proficient in electronic component repair? If not, then leave this sort of repair to a service professional.
You can find parts here:
Sunbeam Mixer Parts
KitchenAid K45SS... | Answered on Jan 28, 2018
Tip the machine upside down on a towel, centralise the hinge pin and tighten the grub screw that locks it into place. This is right up inside the pedestal, there is only one screw there to see.
Now stand it up and fit the mixing bowl & flat paddle, turn the machine on speed one, if the paddle is tinging on the bowl then we now need to set the head height. Turn the motor off.
Raise the motor up and from the front of the machine look in by where the motor hinges on the pedestal. You can see one screw head there. If it's tinging the bowl then you need to turn the screw anti clockwise enough so that the paddle no longer tings on the bowl.
Once it's stopped tinging put it onto max speed and make sure it still clears at high speed, if not turn the screw until it stops tinging. That's it.
KitchenAid K45SS... | Answered on Jan 02, 2018
the motor brushes are worn out and the bushes are worn allowing it to "pole "out
the fix is a replacement unit
KitchenAid K45SS... | Answered on Dec 11, 2017
You need new planetary gears in the head. Did you make a lot of bread in it, or heavy doughs? It wears them down. Contact them for professional service.
Warranty service from here
YOUR CENTER FOR SERVICE SUPPORT
Service Centres are accessed from here.
SERVICE LOCATOR
KitchenAid K45SS... | Answered on Nov 27, 2017
KitchenAid K45SS Classic Stand Mixer Logo
613 questions posted
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
simply wont turn power
  • Food Mixers
