20 Most Recent KitchenAid KCMS135 Microwave Oven Questions & Answers
After 20 years of service, call in a replacement.
KitchenAid... | Answered on Oct 22, 2017
1100 watts
KitchenAid... | Answered on Nov 23, 2013
either the high voltage diode,capacitor,or the magnetron tube is dead shorted,remove the leads off the magnetron tube,but check the diode and capacitor with an ohmmeter to check these for a shorted condition before trying a new fuse,if it builds high voltage then its the mag tube
KitchenAid... | Answered on Jan 07, 2013
Hi, concerning your microwave. The wrap around case on this unit has to be removed to get to the light bulb. Be sure the microw. is unplugged. Hope this helps.
KitchenAid... | Answered on Jan 18, 2011
RESET THE BREAKER
KitchenAid... | Answered on Dec 07, 2007
The first step is to be sure it's unplugged from the wall outlet. I have critical safety & disassembly info at my site, but in a nutshell: - If it's an over the range design and has a grille across the top, that will have to be removed. It will have one or more screws and/or clips. Then you remove the now visible screw at the top of the control panel frame, then lift up and forward. Don't pull hard on the wires. If you disconnect them, mark them exactly, and look out for locking connectors - don't force them. You can then see the door "hooks" and get the door open. (If it's a counter-top design that's built in, it will need to come out the wall and have the outer cover removed). You can see my listing here for a link to my critical safety info and disassembly info: http://tinyurl.com/yzjozk For exploded views and to order parts (the back pin of the handle button probably broke off) visit: http://tinyurl.com/gv383
KitchenAid... | Answered on Jan 26, 2007
Yes, unless a technician may have removed it during a previous service. It should be located behind the controller assembly, sometimes in a small envelope.
At my Web site, I have a video showing you how to remove a typical microwave controller in about 5 minutes.
http://www.microwavecontrol.com
if you have other questions, please feel free to contact me directly by email through the Web site or at pupista@gmail.com
KitchenAid... | Answered on Nov 14, 2019
Yes, it is probably a bad relay. Usually appliance techs just replace the whole control board, because those relays can be hard to find and buy.
KitchenAid... | Answered on Oct 14, 2019
Yes, it is most likely a bad relay on the control board.
KitchenAid... | Answered on Oct 05, 2019
Hi Jill, what the screen indicates is that the door is not closed
There are a number of internal contacts that have to be closed for the microwave to work
If any of them are wrong, they can give you that information.
Depending on the brand there may be between 2 or 3 contacts in the door area that generate that warning
Indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Jill, lo que te indica la pantalla es que la puerta no esta cerrada
Hay una serie de contactos internos que tienen que estar cerrados para que el microondas funcione
Si alguno de ellos esta mal puede darte esa informacion
Derpendiendo de la marca pueda haber entre 2 o 3 contactos en la zona de la puerta que generan ese aviso
Indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
KitchenAid... | Answered on Sep 12, 2019
There are interlocks and micro-switches to prevent accidental running with the door open. The issue with the lock is preventing operation. You need to have it professionally serviced.
KitchenAid... | Answered on Sep 09, 2019
You can find helpful Kitchenaid parts diagrams and get parts at affordable prices for most models from The Pros by entering your model number here:
KitchenAid... | Answered on Jun 30, 2019
For the KitchenAid microwave, model: KHMS2050SSS2 I found that i did not have to remove the screw. what i did was loosen the screw as much as it would go before getting tight again.(hard to screw) then on the bottom end of the door hinge (lying on its side) i pryed the bottom hinge off its mount. (with flat head screwdriver) from there i was able to get at the screws to separate the black surrounding stuff from the outside door... then finally i could get inside to get at the door panel controls. I noticed a whole bunch of condensation and on the back of the touch panel (electrical board).. i will replace that part as I think that is the culprit as to why the keys get pressed randomly, beeping randomly and wonkiness :)
KitchenAid... | Answered on Mar 15, 2019
Microwave Ovens Logo
10 questions posted
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
microwave kcms 135h makes loud sound
  • Microwave Ovens
