20 Most Recent KitchenAid KHMS155LSS 1000 Watts Microwave Oven Questions & Answers
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If not, please reply back with your brand and model number so we can help you better.
In many brands there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
KitchenAid... | Answered on Mar 09, 2018
The clicking sound would probably be a realy on the Circuit board. Do you have it set on Full power?? If it is set on a lower power setting the relays will open and close to try to regulate the cook power.
KitchenAid... | Answered on Oct 04, 2017
NO sad to say it can not .
KitchenAid... | Answered on Sep 28, 2017
http://wiki.brandoncurtis.com/w/File:Microwave_Wiring_Diag this is a good diagram of a standard microwave. ive pretty much only seen on single mag ovens. "F" usually has a single wire from the hvtrans. "FA" is usually the gang off the cap.
KitchenAid... | Answered on Jun 13, 2017
KHMS155LSS0 - May 27, 2017
On many models you can open the door all the way and gently lift it off.
Otherwise, you have to do some disassembly.
The support page for your model, with manuals, is here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
KitchenAid... | Answered on May 28, 2017
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
pupista@gmail.com
KITCHENAID are a budget make despite what you paid. it is better to buy a company that specialises in microwave ovens rather that a company that buys cheaply made products in China or Taiwan and badges them. As you know KitchinAid is a company that does all sorts of kitchen gadgets and utensils. Toshiba and Panasonic are the brand leaders. GE are long established.
The problem with yours sounds like a safety interlock problem. Every microwave has about 4 safety switches attached to the door so that it is impossible for the unit to be run with the door open. They are small micro-switches that are adjusted like a hair trigger so that as soon as the door moves, power cuts. If it is the switch, it is a cheap fix, if it is the Magnetron, it isn't, so diagnosis is needed by a reputable company. You can't take it apart as they use security screws because of the dangers of cooking yourself and the high voltages in the capacitor, and poisonous Beryllium in the magnetron. Your call on fixing or buying new.
KitchenAid... | Answered on Mar 11, 2017
A fridge that is still working after 13 years has done well. Try defrosting it from time to time.
KitchenAid... | Answered on Mar 02, 2017
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part number for the model number you provided varies depending on color, so make sure you order the correct one for your oven. You can view an exploded view of your microwave door here:
http://pcappliancerepair.com/model-display.php
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you
KitchenAid... | Answered on Mar 25, 2016
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
KitchenAid... | Answered on Feb 24, 2016
check the air filter and cooling fan.
My grill has also fallen off twice. It usually results in the tabs breaking off. My solution has been to add tiny (1/2" x 1") shims in the slots where the tabs have broken. Look carefully. There are two tiny channels. I wedged the wood in and then reattached the grill using sheet metal screws in the same screw holes. It won't come down again. In three years since doing the kitchen with all KA appliances we have replaced the grill once. We had the stove removed and replaced by the appliance company at no charge after 4 months. We had our ice maker replaced out of warranty. I would never recommend KA appliances to anyone. The quality is absolutely terrible.
KitchenAid... | Answered on Jan 16, 2016
your better to dismount the door first
you may need to remove the top case
{no power empty the glass out etc incase you need to tip it over}
sometimes you need to remove the whole top panel
either look for the expoded view for it also
and take lots of pictures first and as you go
go for it you can do it
its easy
i recon 8 screws max for the top of the case
and 4 screws for the top hinge
and then lift off the front
four screw to take off the actual front
and 2 screws for the handle
,,,, thats 14 screws in and out
KitchenAid... | Answered on Jun 04, 2015
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
343 questions posted
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
replace door handle
  • Microwave Ovens
