20 Most Recent Weed Eater Fl26 Feather Lite Plus String Trimmer Questions & Answers
You can get a manual from the Weed Eater website.
Weed Eater Fl26... | Answered on Aug 21, 2014
Hi Sam...
Sounds like you still have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Weed Eater Fl26... | Answered on Apr 28, 2013
Dash lights flashing on my 5205
Garden | Answered 18 hours ago
Air trapped in the fuel filter is normal. Air bubbles in a fuel line would imply a cracked fuel line.
Garden | Answered 19 hours ago
Likely the recoil starter is kaput. Removing spark plug so there's no compression, then pull starter. If it's still hard pull, remove recoil starter assembly and spin engine by hand. If engine spins freely, replace recoil start.
Garden | Answered Yesterday
Precisely yes, they were grown in the open fields, dont know if they were along I-80 tho.
You can get more info here probably: http://expertplantman.com/
Garden | Answered 3 days ago
https://partscatalog.deere.com/jdrc/sidebyside/equipment/70454/referrer/navigation/pgId/2397003
Familiarize yourself with fender deck footrest attachment points.
You have to remove the seat and the fender deck footrest. Pedals, cut height adjuster knob and whatever else.
Google (amf)(c2580020)(manual) without parens.
Sorry.This is not a shop. Try the manufacturers agent.
Garden | Answered on Dec 01, 2019
Probably switch is bad and should be replaced. Temporarily you could short wires going to the switch but you have to remember that you no longer will have that safety feature and machine could be started without operator on the seat or could drive itself when operator is no longer on the seat.
Damaged shear pin. Need to be replace. Another possibility is broken drive belt
Many factors are involved. The abrupt change in environment is the most likely cause. This includes sunlight, soil moisture, relative humidity, and ambient temperature.
It could also be if the entire plant was in full bloom (no immature buds) it ran through it's normal bloom cycle.
So it's difficult to say which of the many factors are the main problem.
Garden | Answered on Nov 28, 2019
IT BEING WHAT I DO NOT DO THE NUMBER THING ON FIRST ATTEMPT
Weed Eater Fl26 Feather Lite Plus String Trimmer Logo
6 questions posted
Top Weed Eater Garden Experts
Bonard Allen
knot
knot
Bill Boyd
Are you a Weed Eater Garden Expert? Answer questions, earn points and help others
View Most Popular
Weed Eater Garden
  • Weed Eater Garden
Most Popular Question
put in line weed eater feather lite plus
  • Garden
