20 Most Recent Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA Questions & Answers
I need to replace the
Open the following link for Intermatic parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
8/5/2021 7:52:20 PM • Intermatic... • Answered on Aug 05, 2021
What is the difference between Intermatic Timer Model #R8860P101C and R8860P101D?
you should be able to find what info you need here https://www.reference.com/?o=36355&qo=contentPageReferenceLogo
3/3/2017 3:33:56 PM • Intermatic... • Answered on Mar 03, 2017
Last zone stay on all day
check that tabs arent broke
4/26/2015 3:14:39 AM • Intermatic... • Answered on Apr 26, 2015
Someone installed irrigation service(No model no on box - part no 638400-01). The man went AWOL without leaving an operating manual with me Do you have a rep in Cape Town that can assist?
find an irrigation company near your home maybe been in business for many years and see if the could asst. you with that information
3/6/2015 5:05:07 PM • Intermatic... • Answered on Mar 06, 2015
Automatic sprinklers (Intermatic timer) do not
If manual override works, and dial rotates on time each 24-hours, then worn trippers are suspect.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Upvote the help.
11/20/2014 11:43:05 PM • Intermatic... • Answered on Nov 20, 2014
How do I wire a Light switch timer to a 2 way light switch?
http://waterheatertimer.org/How-to-wire-timers.html Single-pole timer Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/19/2014 4:26:32 AM • Intermatic... • Answered on Aug 19, 2014
0answers
0answers
Zone shutoff
Be the first to answer 4/15/2014 3:31:35 AM • Intermatic... • Posted on Apr 15, 2014Be the first to answer
I have 4 zones can run them manually; but they
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
4/14/2014 3:57:32 PM • Intermatic... • Answered on Apr 14, 2014
Check battery state
Same as a 12-volt cell, charge the battery fully first, then let sit a few hours. Get a hydrometer from the nearest auto store, and measure the specific gravity of each cell (directions and measurements will be in the package). Each cell should read a value (for instance 1.20). If all are in the good range, then something else is going on. If one is low (for instance 1.0, while the rest are 1.2), try to run the battery down pretty low, then fully recharge it again, then retest. If same problem, that low cell is dying. Not much you can really do about it though, once a cell starts failing the battery is pretty much done for. Although it'll be hidden some, because you have 24 cells averaging out to 48V, so a cell that should be "2.0" nominal, reading only 1.0V for instance, isn't going to make much difference. However the rest of the cells are going to begin having problems quickly as they reverse charge through the dead cell, etc. It'll also affect other batteries, as they begin to reverse charge through the dying battery, or fail to completely charge (or overcharge) as a result of the charging circuit trying to get back to 48V. (If you only have 46V of nominal cell capacity (due to one dead cell), the charger is going to want to keep charging until it reaches 48V (actually higher, the fully-charged cutoff is above nominal, not going into that here). So basically it's going to overcook the rest, trying to get to that peak value that it wants to reach.
12/4/2013 10:59:24 PM • Intermatic... • Answered on Dec 04, 2013
Timer works on manual but not auto
Copy following link:http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.htmlhttp://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdfAdd comment and describe timer in detail for possible identification and more assistance If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
4/7/2013 4:01:47 AM • Intermatic... • Answered on Apr 07, 2013
0answers
Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA Logo
65 questions posted
Top Intermatic Electrical Supplies Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Electrical Supplies
Most Popular Question
check battery state
  • Electrical Supplies
