20 Most Recent Magic Bullet Nutribullet Blender Questions & Answers
Sounds like the extractor bearings may be seizing due to rust.
This YouTube vide should help see if it’s the same thing and how to fix it!
Good luck
https://youtu.be/Iw6VXRSHyNM
Magic Bullet... | Answered on Mar 28, 2019
If the blades do not turn and you notice hot base hot or a burning smell, unplug the power base and let it cool for an hour. The powerbase will reset once the unit is unplugged.
They recommend not running for more that 1 minute bursts.
strawberry/banana num num !!!
Magic Bullet... | Answered on Jan 09, 2018
The cup rim had gotten into it while stored. It looked like part of the base. As another user noted, the inside of the base is flat, with no ridges.
Magic Bullet... | Answered on Mar 11, 2017
blender parts in Australia are virtually non existent
it is cheaper to junk it and get a better model
the trouble with blenders under 1000 watts is that the motor is not good enough and they burn out ( two for the price of one is the clue to reliability)
it it is fairly new and still in warranty get it replaced
Magic Bullet... | Answered on Sep 20, 2016
You might consider the cost to repair vs purchasing a new one. Depends on the model, but looks like you can get a replacement for $100 or less. Warranty on small appliances are usually a max of one year, but you would have to check your paperwork.
Magic Bullet... | Answered on May 25, 2016
Here's an article that might help you with charging your Kodak Playsport camera:
Simple Trick to Get the Kodak PlaySport Camera Battery to Charge
Magic Bullet... | Answered on Apr 10, 2016
link shows problem, press the helpful button
HOW TO FIX YOUR NUTRIBULLET
Magic Bullet... | Answered on Jan 17, 2016
Have you got something caught in it? Is it still under warranty? I am guessing but the mechanism inside the base should drop when you push to twist. Check is this is happening. If not then that may be the problem
Magic Bullet... | Answered on Jan 09, 2016
There are 3 white plastic posts on the top inside of the power base. Push these downward to loosen it. Its full of sticky stuff because of overfilling. You can also put some oil on it. Buy parts from ebay and amazon seller amazingearth.
Magic Bullet... | Answered on Nov 04, 2015
Go to the manufacturer website and maybe you can have or get warranty repair. It could also still be under warranty.
Magic Bullet... | Answered on Jul 30, 2015
return to place of purchase for refund .
Magic Bullet... | Answered on May 01, 2015
There's 3 tabs on the inside of the base that get pushed down when you push the cup in. Two of them have switches on them, sometimes they can break. Make sure they are being pushed down. If not, it could be one of the switches inside.
Magic Bullet... | Answered on Apr 26, 2015
try heating the jar with hot water before removing it
Magic Bullet... | Answered on Apr 21, 2015
Magic Bullet Nutribullet Blender Logo
186 questions posted
Top Magic Bullet Blenders Experts
R.A. Ellis
R.A. Ellis
 Russ Hill
Russ Hill
Bill Boyd
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Bullet Blenders
Most Popular Question
mine stopped working makes sound
  • Blenders
