20 Most Recent
Navy Seal Luminox Watch Questions & Answers
On my Luminox 3051 BO
Sorry Robert but it is likely you will have to accept and get used to it. The movement's seconds hand is just not calibrated to the exactness the dial is printed in. Notice as your hand moves it sometimes lands on a marker and gradually stops lining up and then as it reaches another part of the dial it will start lining up again. However it never is consistent as to what markers it lines up with. Lots going on behind the scenes (in your movement) that is inherent in battery powered movements.
3/11/2011 9:25:53 PM •
Navy Seal...
Answered
on Mar 11, 2011
Watchband Adjustment
These type of watches have push pins and can be rather tricky if you do not have the right tools. Can also damage the watch if you DONT have the right tools.
My recommendation is to take it to a local jeweler/watch repair so that it can be done professionally.
Best wishes.
8/11/2010 3:21:41 AM •
Navy Seal...
Answered
on Aug 11, 2010
Luminox watch band adjustment
Those type of bands take a special push pin to push out the pins and can be rather tricky. My best advice would be to take to a local jeweler/watch repair as they have the best tools to do it and it normally is less the $15 to do and worth it.
Hope this helps.
8/10/2010 11:50:15 PM •
Navy Seal...
Answered
on Aug 10, 2010
LUMINOX DEAD IN THE WATER!!!
No real way to clean it yourself, you need to take it to a professional who can diassemble it, clean it then reseal...unfortunately that takes tools and the knowledge...dont try at home, if its gotten wet, it WILL need to be taken apart and worked on.
11/14/2009 9:49:00 PM •
Navy Seal...
Answered
on Nov 14, 2009
Hi, i have a Luminox 8100 sewries, i hav just had
http://www.manualsonline.com/manuals/mfg/hamilton/251471.html
Try this page and get the manual, its free just decline the newsletter..the movement is an ETA 251.471 and these are the setting instructions...good luck :)
11/14/2009 9:45:54 PM •
Navy Seal...
Answered
on Nov 14, 2009
Luminox Titanium Watch
you set it using the wheel pull it out , it should have two positions, one adjust time the other one date and chronograph, I see if I find full manual.
8/3/2008 8:52:58 PM •
Navy Seal...
Answered
on Aug 03, 2008
Stopwatch
You need to calibrate it. In normal time mode, pull the crown out all
the way and then use the pushers to step it back to the zero position.
When finished, push the crown back in. You can also calibrate the
sub-dails in a similar fashion.
4/1/2008 3:24:04 AM •
Navy Seal...
Answered
on Apr 01, 2008
Was mr rogders a navy seal
Ever even in MILITARY...
NO...
Fred Rogers has also been the subject of such rumors,
all of them false.
FLATLY DENIED by Snopes:
http://www.snopes.com/radiotv/tv/mrrogers.asp
http://snopes.com/
3/25/2017 8:11:28 PM •
Navy Seal...
Answered
on Mar 25, 2017
