20 Most Recent
Oster 4134 / 4126 Classic Beehive Work Top Blender Questions & Answers
How do I replace the fuse on my Oster Blender?
I just had the same problem too and ordered the fuse online with the link above. Thanks lele44!
The four feet on the bottom are easily removed with a 1/4" socket slipped inside the each rubber foot fitting.
I'm glad I found you. I saw some downright horrible reviews of my local Oster appliance service center here:
http://www.insiderpages.com/b/3723327730
Rob
Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
Osterizer
Thanks to some good leads, I determined the cause of the problem and ordered a part. Hopefully, that will resolve the problem.
Help with a Dismantled Osterizer Classic Blender
With the unit upside-down and the bottom off the wires on the right side of the switch go like this:
yellow on top
black on middle
red on the bottom
No wire connects to the 4th connection point (top left side).
R.
My rarely used Sunbeam Blender Model #4181 stopped working
It sounds like one of a number of things...
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
