20 Most Recent
Rival 38651-C 6-Quart Questions & Answers
Corningware crock pot
for replacement parts information on Corningware products, you may call toll free (in North America) 1 800 999 3436.
All Three Lights Blinking
We have their 6 quart Crock Pot. Same problem cited here!
We have found that, if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state. It has worked for us on several occasions so we trust it and have found no "adverse results"!
Hope this is a help to others.......
Water coming into refrigerator
Evelyn,
More than likely (I can't be sure from here!), your icemaker "motor module" has failed. This module controls the amount of water that goes into the ice tray. If the timer fails, the water valve can stay open. Also, if this is a new unit, or a used refrigerator you just installed, all you may need is to reset the timer on the motor module. The icemaker must be removed to do that. The tray fill time varies with the local water pressure. If your water pressure increases for some reason, the time must be shortened to avoid overfilling the tray.
Water Coming in basement
check out side where the water is going into the basement, aside from the gutter down spout, you going to need pack some earth so that the water will running towards the yard. If it is where the gutter down spout is, then you need to get a gutter extension direct the water some where else.
DO not paint the basement wall, you will have mod. however, you can waterproof the wall when the weather gets to be above 55 degree.
Replace crock
I have a Tricity TSC09 6 litre Slow Cooker and I just love it its so handy. I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of the same shape and the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker .Now I also have a removable crock replacement as well just in case I smash that too. Hope this helps if you cant find spares and have an expensive slow cooker.
