20 Most Recent
Rival 2275WP Food Processor Questions & Answers
Where can I order a new ring collar for Rival
After an extended period of searching small appliance parts sources I totally understand your question here. Even the user manual does not list a replacement parts source. I was unable to locate any OEM source for the ring collar.
You can try calling Rival at this number
1-800-557-4825
or email here: (500 Char limit)
https://secure.rivalproducts.com/ContactUs.aspx
Thanks for giving Fixya a chance to help you.
Kelly
My ring collar is
Hi, after an extended period of searching small appliance parts sources I totally understand your question here. Even the user manual does not list a replacement parts source. I was unable to locate any OEM source for the ring collar.
You can try calling Rival Customer Care at this number to make a request for the part.
1-800-557-4825
What is the purpose of the washer and where does
The purpose of this washer is to reduce the friction between the auger and the body of the grinder head. During the grinding process the auger is pushing food/meat forward to the disc and respectively reacting itsef backward. So, the washer goes over the back shaft of the auger as a surface of the contact with the body. You have to put it over this shaft before assembing the auger with the head body. The pasta maker attachment and the grinder both have identical augers.
Need the instruction manual to assemble this
What's to assemble, first of all its a meat grinder, you put the hopper on and insert the grind mechanism which is a shaft that has curled ridges on it, it should lock in, then you need to place the cutting blade on, that looks like four corners, and then either the fine or coase meat grinding wheel with the small or large holes in it, then the plastic part that holds it all together and tighten down, just make sure to wash and clean it right away, also dry the pieces, hot soapy water, they are usually carbon steel and can rust, hope this helps
