20 Most Recent
Rowenta Ultra Professional DM991 Iron Questions & Answers
Power cord on rowenta dm991 is split- needs a new
On the end of the iron there are 2 screws - remove them; on the bottom of the end there is a small slot - put a small screw driver in the slot and pull on the end; you will find the wire that goes into the iron - get a replacement from an iron shop and you are good to go!
How do you fix a seal on a Rowenta Iron?
To try and seal the water leak will possibly render the appliance dangerous.
I would speak to Rowenta and ask the question. They may well extend the warranty if you suggest it wasn't used for say a few weeks after purchase etc.
How to fix water leaking out of bottom of Rowenta steam iron
I'm on my fifth Rowenta iron. The first four eventually started to leak. I keep buying Rowenta because I get the best results except for the leaking. I've been using filtered water even though the manual sas to use tap water. I will start o use tap water. The fifth one I bought was highly rated by Consumer Reports. If this new one starts to leak, I'll bring it back and buy a different brand.
