20 Most Recent
LG 47LV5500 47 Class LED TV with SmartTV, LED Backlighting, TruMotion 120Hz, Wi-Fi Ready, FuHD 1080p Resolution, DLNA Certified, ENERGY STAR Qualified, Picture Wizard II, Intelligent Sensor, 5000000:1 Contrast Ratio DCR, 120Hz MPRT 47LV5500 47-LV5500 47 Questions & Answers
LG vertical line
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations
. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; (
Exclude the model number), in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
