20 Most Recent
Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969 Questions & Answers
Jacuzzi majic touch won't turn on
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.If the bath pump comes on then you know you have a bad air button.If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.If the bath pump comes on then you know you need a new air switch in the motor.If the motor does not come on then you need a new bath pump.Rod
US Parts Center888-521-6183
