20 Most Recent Xerox Workcentre 7345 Printer, Copier, Scanner Questions & Answers
Xerox 7345 error code- 004-345 how to solve?
Hi, Please power off the printer, wait 30 seconds and then power it on again. Thank you.
8/1/2022 10:46:32 PM • Xerox Workcentre... • Answered on Aug 01, 2022
2answers
Whats transfer belt cleaner xerox 7345
Confirm which model Xerox Copier/Printer you are using? If it's an WorkCentre 7345: Image Transfer Belt Cleaner Part Number: 049K92448
2/14/2021 3:04:19 PM • Xerox Workcentre... • Answered on Feb 14, 2021
Xerox 7345 workcenter fault code 024-360
Goto the Xerox.com website. Sorry, Good luck.
2/8/2020 5:31:58 AM • Xerox Workcentre... • Answered on Feb 08, 2020
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440. http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
10/7/2019 12:30:24 PM • Xerox Workcentre... • Answered on Oct 07, 2019
Error code 004-363
Black Imaging Unit Motor Failure.
5/12/2019 10:29:15 AM • Xerox Workcentre... • Answered on May 12, 2019
Error code 007-960
007-960 MSI Paper Mismatch 2 In the UI specified plain paper or thick index paper. Try this link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=399,E=0000000005965351572,K=3062,Sxi=1,Case=obj(47319)
5/24/2016 7:26:13 PM • Xerox Workcentre... • Answered on May 24, 2016
Unable to start,the waste bottle need to be replaced
Are you sure the clear section is cleaned. The waste box may have a chip on it that tells the copier I am full, so vacuum iy out will not help. if you see a clear sectoin of plastic that has to be clear or the sensors will read the box as full. Replace the box, recommend always have a spare, so that during a print job if it come up replace the box and keep running. Another could be you are required to clear a counter every time you replace the box as long as the counter is not clear copier thinks the box is full. Go to Xerox web site contact them Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2016 3:41:33 PM • Xerox Workcentre... • Answered on May 07, 2016
Cleaned waste bottle thoroughly but still the machine says unable to start replace waste bottle ..........what code i had to provide and how?
Are you sure the clear section is cleaned. The waste box may have a chip on it that tells the copier I am full, so vacuum iy out will not help. if you see a clear sectoin of plastic that has to be clear or the sensors will read the box as full. Replace the box, recommend always have a spare, so that during a print job if it come up replace the box and keep running. Another could be you are required to clear a counter every time you replace the box as long as the counter is not clear copier thinks the box is full. Go to Xerox web site contact them. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2016 3:39:42 PM • Xerox Workcentre... • Answered on May 07, 2016
Xerox 7345 error 008-164 paper is folded with jams and 008/164
That error indicates that the paper was not sensed as passing the pob sensor which is right at the registration rollers. If the paper is folding there, the main cause is the registration clutch not being initialized or slipping. Replace registration clutch, part number: 121K22220 http://www.iteminconline.com/121k22220_121k22220-xerox-7760-registration-clutch.htm
3/28/2016 7:03:28 PM • Xerox Workcentre... • Answered on Mar 28, 2016
Xerox Workcentre 7345 Printer, Copier, Scanner Logo
47 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
xerox 7345 error code 004 345 solve
  • Office Equipment & Supplies
