20 Most Recent
Relic Degrade Pocket Watch Questions & Answers
How to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
I have a cheap pocket watch that needsa new
Pocket watches are 99% with the back snap-on/sanap-off opening. Never came across the screwback. Get the knife with the solid blade, insert the blade in the groove between the case and the caseback and push it in quite hard using lever action (pry up). At the same time make sure the blade do not slip into the movement, as it will damage your watch.
If there is no groove between the case and the caseback, then watch must be opened by removing bezel (metal ring holding glass in place). Open the same way as for the caseback, just be VERY carefull, as any slip of the blade will leave the marks on dial.
Do not forget to rate, please.
Some of the numbers on my relic pocket watch fell off.
Unfortunately you will not be able to get the watch glass off without braking it. Watch glasses usually are friction set or glued into the watch bezel using special press or special glue. Both are of such a good quality, that it is allmost impossible to remove the glass without special equipment.
You can try, of course, but it will be on your own risk.
The best way is to find your nearest watch repair shop and ask for help.
How to set the 24 hr time on a women's relic multifunction Zr15992
What company made this watch? The only watch I can find with that name is not a digital watch so the 24 hour display does not possibly apply. Are you referring to the date display not changing at midnight? A quick trick that might work is to Roll the 12 hour dial forward 12 hours, (example 12 noon forward to 12 midnight).
The dual time display is for when people are using two different world time zones. For example, for people who work regularly in two different countries. Using it means you don't have to keep reseting your watch when you change countries.
