20 Most Recent
Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon Questions & Answers
Water heater is beeping with
if water heater is beeping E-2 it means that the water heater has gotten to high above water heater set point. Things to check
- there hot water being feed from boiler still
- is zone valve or pump isolated stopping flow of water to water heater
-check sensor readings
What is the proper temperature setting for a hot water heater
The answer different if you have: concerns about diseases, a dishwasher, young children or elderly that can be easily burned, electric vs. gas heat, type of plumbing (e.g. PEX or Copper).
In 1988, the Consumer Product Safety Commission recommended that water heater manufacturers preset the maximum temperature at 120 degrees Fahrenheit to prevent burns. Since several states have mandated this maximum temperature.
HELP... my flush line from
Make SURE that everything gets dried out COMPLETELY... then BEFORE appyiing power again....
Use a hair dryer if needed and be patient in the frying... do not get it too close...
if everything gets dried out well and then power is applied is should work again...
Take your time and do it right the first time!!
heatman101
Amtrol Boiler Mate WH-7P (oil).
If you check for power at the tank, (the black and white wires) you should read voltage, either 24 vac, or 120 vac, depending on how it is wired. If there is no power there, then you will have to chase power back to where you do have it. There is no fuse or reset button on this model.
Our Champion well pump has quit
is there any water in the well, you might have to check and make sure you have enough water it is supposed to be submerged in water not just the tip of the pump, you will have to pull the pump out of the ground in order to check this, just for caution you might want to have your local plumber come out good luck
Hank I thought my pressure switch was also bad.
just a suggestion but your pump could be clogged in the ground, just by readind you are on well system? the contacts are together because they are trying to pull water to get up to the proper amount of water pressure. that is why they contact then overheat release then contact again, how old is the pump????
