20 Most Recent Maax Brio II One-Piece Neo-Angle Corner Shower with MAAX IES 1/2 System - 1 Questions & Answers
Its probbably the hose connected to the valve, try screwing it back on and turn the water up slowly, if that does not help, check your local radio shack
Maax Brio II... | Answered on Nov 06, 2019
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Maax Brio II... | Answered on Nov 08, 2017
www.maax.com
Maax Brio II... | Answered on Aug 20, 2014
Request the manual from Maax.
Maax Plumbing | Answered on May 15, 2018
and what is your question --if you want to complain notify the company
Maax Plumbing | Answered on Apr 30, 2018
There are 2 types of litghly cover. A twist off (1/4) turn and a some pry off. It shouldn't be required hi torque. Try twist off first counter clockwise
Maax Plumbing | Answered on Jun 02, 2017
Generally the drains that are controlled from the
OVER-FLOW do indeed have a rod that goes down
from the face of the overflow... which lifts (opens)
the drain by lifting a hollow (typically plastic) sleeve
from in front of the outflow of the drain...
It is hollow to allow the OVERFLOW to work at all times.
The version you seem to have... WOULD have a
bellows like device that pushes on a plug lever...
More complex... but I seriously believe both may be
serviced through the OVERFLOW
(will attach a drawing below)...
OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE...
Once you see the diagram of the drain MECHANISM...
you will be able to see that jamming in a coat-hanger
was a terrible idea.
You can still most likely remove and repair the
mechanism ... (from the over-flow)
ELSE
You are looking at buying a new one and installing the entire drain from the bottom (hopefully).
Diagram of drains:
Go to Bing homepage
Carnac the Magnificent
Maax Plumbing | Answered on Mar 24, 2017
Maax Brio II One-Piece Neo-Angle Corner Shower with MAAX IES 1/2 System - 1 Logo
10 questions posted
Top Maax Plumbing Experts
Jay Saari
Jay Saari
Level 1 Expert
john h
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Maax Plumbing
  • Maax Plumbing
Most Popular Question
remove shower valve maax shower leaking
  • Plumbing
