20 Most Recent
Sunbeam 2366 MixMaster Series Hand/Stand Mixer Questions & Answers
I have a Sunbeam Mixmaster from mthe 1970s,
If this mixer sits on a stand, first remove it from the stand. Turn it upside down and shine a flashlight into the right side socket to look for obstructions. When you say you swivel the head, do you mean you rotate the handle? This is how to eject the beaters after use. It may be that the ejector on the right side is stuck. If so, you will need someone with mechanical skills to disassemble & repair.
Beater keeps falling out. The
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG --
-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --
-- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --
-- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body.
I have a Sunbeam 2366
The center plastic post under the speed control knob is cracked.
Call Sunbeam at (800) 458-8407
The plastic control knob part # is 084164-100-854.
The cost is $8.31 with FREE SHIPPING!
Just remove the Sunbeam sticker.
Remove the old knob screw.
Clean the general area.
Place the new knob,tighten screw
Put Sunbeam sticker back on.
TEST UNIT.
