20 Most Recent
Kohler Fairfax Single Control Lavatory Faucet Lever Handle w/ Pop-up Drain Questions & Answers
Our Kohler Fairfax kitchen faucet 12176 has a
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Fix cloudy tap water
Install a screw on filter to keep it clean.Thanks for asking and I hope it helps.
Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
