20 Most Recent
Swisher 44 in. 12.5 HP Briggs & Stratton Trail Cutter Questions & Answers
Swisherinc com
if by floppy do you mean that tips move up down 1/2 inch yes this is normal, if they move more ck spindle bearings ill bet your missing a few balls in there , and nope no belt should have chunks missing , and yes defective belts will slip and not get proper blade speed from engine to blades
clean out belt path after every use , that belt guide path is a magnet to sticks and stuff collecting there , also allways use kevlar belts , not ones from a car there not 4 to take the heat a kevlar belt will
Can a bad battery cause clutch to slip?
Not likely. But to eliminate that possibility try connecting a battery charge to the battery and try engaging the blades then. Also check all electrical connection in system for corrosion and tightness. Lastly With compressed air blow all dirt and debris from the mower, especially clutch area and Hydraulic pumps. Check tension on blade drive belt.
