20 Most Recent Sunbeam 4214 Iron Questions & Answers
2answers
My wife's sunbeam microglide iron
I just took apart a Sunbeam iron. This is how it disassembles:
first remove the screw at the base. Next remove the moisture dial top (it should just pop off). This allows the iron to slide apart - the metal base from the top. It should slide about an inch then lift off.
My iron didn't get hot, and what I found is the gear that attaches the temp setting to the electrical was missing a tooth. Perhaps you could set the gear to permanently "ON". In my case I found out with brute force how the iron is supposed to disassemble... time for a new iron...
9/18/2015 7:02:52 PM • Sunbeam 4214... • Answered on Sep 18, 2015
My sunbeam iron started beeping like an alarm, why?
www.laundry.manualsonline.com has free manual
3/27/2015 7:13:04 AM • Sunbeam 4214... • Answered on Mar 27, 2015
How to disassenble bcsbcl-212
laundry.manualsonline.com has free manual.
3/27/2015 7:04:10 AM • Sunbeam 4214... • Answered on Mar 27, 2015
manual
4214 Iron Manual
Sunbeam IronsUploaded on Oct 15, 2013
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
3/15/2013 11:10:37 AM • Sunbeam 4214... • Answered on Mar 15, 2013
How to flush brown fluid from Sunbeam Steam Master
There is commercial iron cleaner, but you can use white vinegar and distilled water to flush it. I would use a mixture of half and half. Then let it steam its little self, when it is clear, rinse with the distilled water again, This kind of thing happens when you use tap water and let it sit in it without rinsing after using. I always use distilled water and empty right away after use. Good luck
3/14/2013 2:14:01 PM • Sunbeam 4214... • Answered on Mar 14, 2013
0answers
How to take iron apart
Look for screws on the handle area
10/6/2012 5:07:24 PM • Sunbeam 4214... • Answered on Oct 06, 2012
Iron not heating
Hi nowlinwellsCheck your power going to the iron...if you have power going to the iron then take apart the iron and check the connection inside of the iron because it sounds like the wire is broken and not getting power to the iron.Please rate me.Bud
10/6/2012 5:06:47 PM • Sunbeam 4214... • Answered on Oct 06, 2012
How to clean a non-stick sole plate iron
I had this iron, and have since gotten rid of it. I cleaned the iron by running it with a solution of vinegar and water, about 1/2 and 1/2. Ran the steam until the solution was empty, and cleaned the nozzles with a q-tip at the same time. It worked temporarily.
5/27/2012 5:03:58 PM • Sunbeam 4214... • Answered on May 27, 2012
tip
Disassemble?
I recently had a problem with the steam button. It somehow during normal use came off its track in the handle and was stuck down in the "slot". After several searches online and this site i tried a knife along all the edges trying to figure out how to disassemble the iron. Well one quick flick with my knife to the side of the steam button and it came out. Well the surprise was the screw under these buttons. Hopefully this can help someone looking to disassemble the iron when they have problems.
on Jun 11, 2011 • Sunbeam 4214 Iron
My non stick sole plate on my Sunbeam iron is
The discoloration is from a reaction of your water and the shield. The best way to avoid this is to use distilled water rather than tap water or use a water filter. I have had this problem at home as well (i have well water) and using a filter "fixed" the problem for me. Hopefully this will resolve the problem for you as well.
Please let us know if you still have the problem and we'll look for other alternatives.
Dan
11/5/2010 9:41:33 PM • Sunbeam 4214... • Answered on Nov 05, 2010
Sunbeam 4214 Iron Logo
65 questions posted
Top Sunbeam Irons Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
View Most Popular
Sunbeam Irons
  • Sunbeam Irons
Most Popular Question
flush brown fluid water from sunbeam
  • Irons
