20 Most Recent
Bulldog Keyless Entry System Questions & Answers
Installing a bulldog security keyless entry
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
When do I need to install a immobilizer
Actually, most newer vehicles come with an immobilizer installed. GM vehicles have had them for years. Maybe the question you wanted to ask was when do you need to install an immobilizer bypass. The bypass is necessary when installing a remote starter on a vehicle that has an manufacturer immobilizer or, transponder key.
Can I reprogram the remotes from 1702 entry system
Yes you can program your remote to work for your door locks and to open your trunk. First make sure all the correct wires are soldered together in the right places. Once all the wiring is right you can program the remote. Here is the address that will take you to the installation guide for your bullydog 1702 keyless entry guide.
http://www.bulldogsecurity.com/pdf/KE100_150_1702.pdf
I suggest following it because it has good tips on how to tell which wires are the ones you will need. For your trunk I know from experience that if you go from the wires on the back of your trunk "pop open" button, the wire that you touch when your test light is hooked to ground that opens the trunk is the wire that you use. As the wire is looking for a negative pulse and thats a negative wire from your keyless entry module.
I hope this helps you if you have any more questions please ask
I installed the KE 1702
where did you tie into the domelight supervision? did you use the yellow black wire in the kick panel? does your unit have dip switches in it? it may be seeing ground when it is not supposed to. not sure but let me know how you hooked it up and what wire you used and i will let you know.
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
