20 Most Recent
Generac 5626 GP Series GP7000E 8,750 Watt 410cc OHV Portable Gas Powered Ge Questions & Answers
Engine is pumping oil back
I am thinking that your air filter is extremely dirty. The engine creates a suction and if the air filter is so dirty that air cannot pass through it, then it will start to **** from the engine block and oil will come into the manifold and drip out through the filter and onto the ground. Have you tried to start and run the engine without the filter (in a clean location only and for a short time) to see if the problem still exists without the air filter? This will determine if the engine is pumping the oil out. If it runs fine without excessive oil being drawn into the manifold, then I would purchase a new air filter (do not reuse these filters) and try it out.
How do you adjust the voltage?
As per instructions says the voltage regulator is automatic/digital. when
you check the voltage is there any load on the generator? if applying
load to the generator doesn't help, you can manually change the motor
speed where the governor connects to the carborator, but it may change
the frequency, but the regulator may fix it.
Applying load will increase the excitation current (its how the
generator knows to start making electricity) anyways, i usually use a
shop light for my load, you can't hurt them with low voltage. the
adjustments for the motor speed will be mechanical (prob. a screw or
linkage) i would call customer service if all this fails, they actually
help pretty good
Hope i helped you.
Thanks for using "Fixya".
Starts runs stops
Owen....sounds like fuel starvation check u have plenty fuel then clean ur fuel filter in line and in tank if u have 1, to check fuel is running ok remove fuel line the end thats connected to carb put in jar to catch fuel if runs ok thats good if slow flow or just dribbling blow through with air line then check again if ok reconnect
6/14/2014 10:16:11 PM •
Generac...
Answered
on Jun 14, 2014
Stale Fuel in gas tank
go to any auto parts store and get one of the products they have to remove the gum in the carburator and line. Some of the products are simply poured into the gas tank along with some fresh gas. good luck.
1/18/2009 11:23:42 PM •
Generac...
Answered
on Jan 18, 2009
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
