20 Most Recent
Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch Questions & Answers
Where can I find a replacement band for my tag
mcdevito75 here, BEST BET, Look for a small watch repair shop in your area for a replacement band, or you may want an orginal band to maintain authenticity, a band straight from Tag Heur can be ordered.
Watch accuracy
it is ok for a new watch to gain or lose more seconds. it takes time for the movement to settle down.
I recently received a Tag Heuer Link Calbre 5
Here is how its done. First remove one end of the clasp (this is much easier on the adjustment side - just depress the pin and remove). Now you can separate the two halves of the first link (actually this is a half-link). Simply grab each half and pull. You may have to do some twisting - do it carefully so that you don't bend the pin. You may have to do some prying - if so, you can use a thin piece of plastic so you don't scratch the link and only pry along the pin so that you don't bend it. Once removed, you can now remove the first full link. Remove it in the same way. Now replace the end half-link and re-attach the clasp. Removing a link from the other side is a little more difficult. The clasp lock is held on with a long pin (slot on one end and screw on the other. One must be held in place while you turn the other. You may need another pair of hands to help you.
If you feel uncomfortable about any of the above, take it to a jeweler - a Tag AD is not necessary but probably best although any jeweler can remove a link if they understand how they are put together. Tell them the link is composed of a right and left half that snap together and they should then see and understand what they need to do.
Tag heuer
It sounds like something has either moved out of place in the movement or something has broken. A qualified watchmaker can repair this for you.
Hope this helps,
Ken
www.yellowstonewatch.com
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)]. Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2. You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3. Cheers!
