20 Most Recent Tasco ® Silver Antler® 3-9x40 mm Scope Matte Black Questions & Answers
3answers
PARTS FOR A TASCO RIFLE SCOPE
Hi, I think they can be found on amazon. here: Amazon com tasco rifle scope parts I hope this was helpful. cheers
4/11/2022 5:44:04 PM • Tasco ® Silver... • Answered on Apr 11, 2022
Scope replacement parts
Nope you can't unless you find a donor scope for spares Most scopes are not user serviceable due to the moisture purging and sealing required
5/17/2015 10:02:04 PM • Tasco ® Silver... • Answered on May 17, 2015
I bought a tasco scope
Here is the Tasco support site for their manuals.
9/10/2011 5:22:36 AM • Tasco ® Silver... • Answered on Sep 10, 2011
We've got the windage right
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Find your manual here Tasco Support Hope this helps Fix ya up.
6/18/2011 1:41:37 AM • Tasco ® Silver... • Answered on Jun 18, 2011
Where can I find a
Silver Antler 2-9 x 40mm scope matte black - firing inaccurate and need to re-set scope
4/22/2011 6:19:44 PM • Tasco ® Silver... • Answered on Apr 22, 2011
The front screw on part
if the frount lens has fell out then its a new scope,,,
11/28/2010 2:30:36 AM • Tasco ® Silver... • Answered on Nov 28, 2010
Hi..I would like to ask
You can use any scope with any rifle as long as you can find a ring/mount combination the fits.
9/23/2010 12:07:32 AM • Tasco ® Silver... • Answered on Sep 23, 2010
I have lost the screw in piece on the adjusting
I would take the scope to a hardware store.I know that Ace has all kinds of machine screws with different diameters,lengths,thread counts,machine screws wood screws,metric,standard,etc. and try to find the right one that seems to fit best.If you have to have it mounted,just leave the gun in the car and bring it out to experiment to make sure you have the right one.Your only other alternitative is to order one from the manufacturer.A hardware store should have one that should fit though and if you find out it isn't the exact one,you can exchange/return.I do basically the same thing for appliances,a couple of screws for a car.Lowes and Home Depot make you buy packages of more screws than 1,so if you find one at a hardware store that works,you may want to go to one of those 2 to buy a package of them in case it happens again but make sure to get the right specs.(length,thread count,diameter).If you want to contact the maker it will probably cost like $3-5 to ship so it's up to you. Good luck and happy hunting!Greg
8/23/2010 8:39:08 PM • Tasco ® Silver... • Answered on Aug 23, 2010
I have lost the screw cap on my Tasco scope 3x9,
Call (800) 423.3537 and ask them, TASCO, caps should be common thread sizes. Otherwise, Midway or someone like that may have replacement caps.
6/19/2010 4:48:53 PM • Tasco ® Silver... • Answered on Jun 19, 2010
I need a manual for Tasco 3-9x40 (red&green
If you go to Tasco's website, they have a list of manuals. Without knowing the model, I cannot link the correct one....however....here is a link to their list of User Manual's...
http://www.tasco.com/support.cfm
1/19/2010 1:19:58 PM • Tasco ® Silver... • Answered on Jan 19, 2010
3answers
How to sight scope in /what scope do i have ?
Real simple Scott.
You can 'Zero' your scope/rifle even if you don't have a laser bore-scope device.
All this is assuming that your used rifle has not had the barrel shot out and that the head-space is still within specs for that rifle. Have all this checked by a gunsmith first. You can dress up a piece of poop and it will be pretty, but still be poop. Make sure yours isn't to begin with. As for the scope, it's hard to tell unless there's obvious damage or it's an antique past it's prime. Try to get as good a quality scope as possible to start with. You would not put one ply tube tires on your mustang and expect to get the best performance, so...
Most rifles are capable of shooting quite accurately, and all things being equal, it's the shooters job of making it happen.
Ammunition should be considered as well. Toss your old military ball ammo and junk from overseas, both of'em. If you want to shoot accurately and consistently, you must spend the bucks for the best ammo you can afford.
You MUST KNOW what the BALLISTICS are for the Cal./type/weight ammo you will be shooting and the corresponding distance it will be shot from.
Make sure your rifle is CLEAN inside and out. A clean rifle is a happy rifle.
Make sure that your rifle 'fits' your body's frame and that you are familiar and practice good rifle shooting techniques.
'Zeroing' is best done from the prone position as that is the most steady position to shoot from.
Do you have a bi-pod attached? Whether you do or not, sandbag your rifle securely but still able to make small adjustments to the rifle position itself.
Set up a target with a 1" black dot at 50rds.
Remove the bolt.
Lay down with your rifle but stay OFF of it, touch it as little as possible at this point.
With out disturbing the rifle look through the bore downrange to your target. Locate the black dot and if necessary adjust your rifle from the **** end until you can see the dot through the bore. Keep making minor adjustments until the dot appears to be centered in the bore. Make sure rifle is secure and steady at this point.
Then without moving or touching the rifle, look through the scope using the correct eye relief distance and locate the black dot. Now using the Vertical(Elevation) and Horizontal(Windage) adjustment knobs, move the reticles(crosshairs) until they both are centered on the dot.
Again look through the bore to make sure that you have not moved the rifle and that the dot is still centered in the bore. If not, adjust the rifle again to center the dot, then go back to the scope and adjust as necessary to move the RETICLES to the center of the dot. It may be necessary to repeat this a few times before you have achieved this particular goal.
You do not mention brand/model of your scope. It probably adjusts the reticle or crosshairs in 1/4minute increments (1/4 inch increments with each individual click movement of the turret knobs at 100 yard distance). IT IS CRITICAL for you to know how your own scope adjusts.
Now, bolt back in and load 3 rounds of quality ammo.
You are going to shoot 3 rounds in succession without getting off the rifle or making any adjustments to the rifle or scope. You are looking for a 3 shot group to determine a rough average of how far and where the rounds are impacting initially. Use good shooting techniques, breath control, relax, sight picture, squeeeeeeze the trigger, follow through the scope, there is no need to take your eye off the scope while doing this, hold your shooting position for all 3 shots.
You will now have to make adjustments of the scope unless you are hitting the black dot already which is quite possible.
Remember that if your scope is a 1/4" adjustment at 100yds, it means that for each 'click' that you adjust either Vertically or Horizontally at 100rds, the reticle/crosshairs will move accordingly 1/4 of an inch Vertically or Horizontally. At 200yds, one click will move it 1/2 inch, at 300yrd it will move it 3/4 of an inch, at 400yrd, it will be 1 inch.
Right now you are at 50yrds distance from your target. Each click from here will move the RETICLES about 1/8 of an inch so estimate the distance that your most central shot of the 3 you fired, is from the black dot and adjust accordingly. You're not moving the RIFLE here, you are simply moving the scope RETICLES so that your point of aim and point of impact coincides.
Now load 3 more rounds of ammo and repeat as above. You should only have to use about 9 rounds to get on target, the black dot.
Once you are hitting the black dot at the 50yrd line, move back to the 100yrd line. Put a fresh black dot on your target and repeat the steps from above. Your first 3 shots from the 100yrd line should be about 1/2 to 1 inch low. Don't follow the bullet strikes! Keep your point of aim and the crosshairs ON the black dot no matter where the bullets are striking on the target. Remember, now at 100yrds your RETICLES will move 1/4inch with each 'click' of adjustment of the turret knobs.
Adjust the scope as needed at this point. Once you are 'ON TARGET'(hitting the black dot), you now have your 100yrd. 'ZERO'.
Now that you have this 100yrd ZERO, you must loosen the turret knobs , both the Vertical(Elevation) and the Horizontal(Windage) turrets and align the '0' on the knobs with the '0' on the scope at the base of each knob. Now tighten the set screws and you are set to go. If you want to know your 200yrd 'ZERO', simply move back to the 200yrd line, your 'come-up' or elevation adjustment should be about 7-9 clicks, at least for .308 168grn HPBT, but you will figure it out for the Cal./brand/wght ammo you are using. WHATEVER the 'come-up' you need to make at 200, 300,400yrds or wherever, be sure to make note of the number of clicks you used to find the Zero for that distance. Use a fine point endelible marker and actually write the ZERO info on thestock of your rifle. You don't need to mark anything for the 100yrd ZERO, it's a given already. Write; 200/9, 300/18 and so on. You should also get your ZERO for the intermidiate, 150yrd, 250yrds etc, distances as well.
Remember that weather conditions, source and intesity of light conditions, your own body condition at any particular moment or day can have an affecf on how you and/or your rifle shoot. Good luck.
4/21/2009 10:22:22 PM • Tasco ® Silver... • Answered on Apr 21, 2009
Caps will not screw off
Many cap threads are reverse. try unscrewing the other direction. If this doesnt work my suggestion is to use physics to get it off.
Image a jar that is 1 litre with a lid that is 10 cm across. it takes x amount of force to unscrew that jar.
Now if that same jar has a lid that is 25 cm across there is a power advantage and a speed reduction.
Now to apply this to your thread caps. try adding layers of tape/cloth onto the thread caps to make it easier to unscrew.
4/8/2009 9:25:41 AM • Tasco ® Silver... • Answered on Apr 08, 2009
I have Tasco 4x16x40 scope. The crosshairs will not adjust or hold. What can I do to get this fixed.
It is impossible to see and movement as the crosshairs move such a tiny amount. Half a millimetre in the sight is 10 feet at the target. The only way to zero in sights is on a fixed bench rest at the range. If you really think they are faulty, return them to the maker for repair. Tasco do have a Warranty and Repair Service.
Customer Service - Tasco
Tasco https://tasco.com > customer-service Warranty Information; Shipping & Delivery; Instruction Manuals; Repair; Returns. You can reach our customer service team M-T 8am-6pm, W-Th 8AM-4:30PM, ... ..
3/8/2023 4:06:54 AM • Tasco Optics • Answered on Mar 08, 2023
How do I change my tasco rangefinder from meters to yards it's on meters but I can't get it to show yards
i have a 15 year old Tasco rangefinder with no mode button and suffered with the meters till today. I disconnected the battery, held down the range button and reconnected it at the same time. 15 years of irritation behind me. It now reads in yards David Hudsoni
2/26/2022 10:52:38 PM • Tasco Optics • Answered on Feb 26, 2022
Tasco ® Silver Antler® 3-9x40 mm Scope Matte Black Logo
21 questions posted
Top Tasco Optics Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Tasco Optic Expert? Answer questions, earn points and help others
View Most Popular
Tasco Optics
  • Tasco Optics
Most Popular Question
parts tasco rifle scope
  • Optics
