20 Most Recent Simmons 511070 4x32 22 MAG Riflescope - Glossy Black Questions & Answers
Scope insternal adjustments do not do anything.
One of the things about bore sighting is there is no shock to the scope. They are meant to have some shock that goes along with an adjustment. Try smaller adjustments and tap the tube of the scope with a screw driver handle after every adjustment. Not so hard you dent it but hard enough to get stuff moving. Hope this Helps FixYa up.
9/1/2011 1:49:55 AM • Simmons 511070... • Answered on Sep 01, 2011
How do I adjust the reticle for a Simmons Mag 4X32
the reticle should be level if its not you need to turn the scope body round in its mounts till it is level and then nip the scope caps up
9/6/2010 7:30:05 PM • Simmons 511070... • Answered on Sep 06, 2010
The elevation adjustment screw will
all scopes are marked for up or down with a " u or d" or a
"+ or -" for up and down
just dont forse the turret screws or you will bust the scope
8/28/2010 1:17:46 PM • Simmons 511070... • Answered on Aug 28, 2010
Have no idea how to set up the sight on my air gun
I don't have this particular model. Chances are, those are not "knobs" but caps. Remove the caps as you would remove the caps from a pill bottle. Underneath, you should find the adjustment dials for windage and elevation,
You can download a generic Simmons scope manual here:
http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
4/4/2010 7:41:14 PM • Simmons 511070... • Answered on Apr 04, 2010
My 303 Lee Enfield does not want to group . Must I change the barrel or must I take it to another gunsmith
I'm thinking somebody messed up the bedding, take it back and have him check his work.
2/12/2017 6:50:20 AM • Simmons Optics • Answered on Feb 12, 2017
My simmons scope is blurred and i can hear things are loose internally
And your question is ???????????????
11/6/2015 7:09:39 AM • Simmons Optics • Answered on Nov 06, 2015
My reticle/crosshair has rotated by about 45 degrees anti-clockwise in my Simmons Deerfield 3-9x50 air rifle scope, is there a quick fix? Or is it a gun shop job?
You could do like my wife did on an old scope of mine, run your finger into it, but then all you see is clear. the olny thing you mght ry is to roatate the scope clockwise about 45 degrees or replace the scope. you might contact Simmons, they might replace the scope for you. Good luck.
3/20/2015 6:28:27 PM • Simmons Optics • Answered on Mar 20, 2015
Need a manual for a Simmons Model 21012 Rifle Scope, 3X - 9X Variable,where can I get one?
Download the appropriate manual from here: http://simmonsoptics.com/global/manuals.aspx
3/11/2015 11:16:24 PM • Simmons Optics • Answered on Mar 11, 2015
0answers
0answers
Scopes
Be the first to answer 4/9/2013 3:46:10 AM • Simmons Optics • Posted on Apr 09, 2013Be the first to answer
0answers
My 22 mag 4x32 rifle
I don't know what you have done already, but, remember there are two areas to tighten. The scope rings to the scope mounts and the rings themselves around the scope.
you have hopefully forgootten one step.
If not, take it to your local Gun store and I'll bet they won't charge you much if anything for looking at it.
4/9/2011 4:50:41 AM • Simmons Optics • Answered on Apr 09, 2011
How do I change the
If you have the Blazer 3-9x32 tur the large ring just ahead of the rear eye piece. That should increase/decrease the mag.
1/10/2011 1:46:16 PM • Simmons Optics • Answered on Jan 10, 2011
Simmons 511070 4x32 22 MAG Riflescope - Glossy Black Logo
5 questions posted
Top Simmons Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Simmons Optic Expert? Answer questions, earn points and help others
View Most Popular
Simmons Optics
  • Simmons Optics
Most Popular Question
  • Optics
