20 Most Recent
RIM BlackBerry Pearl 8120 Cellular Phone Questions & Answers
I cant receive anythin om
Hi,the BlackBerry Pearl is a versatile mobile phone. It's primarily a Smartphone that's suitable for business use but it's also equipped with some decent entertainment features. The pearl can also play music files which you can enjoy with the help of a hands free Bluetooth headset. Let me teach you how to pair a Blackberry Pearl Smartphone to a Bluetooth headset.
Things You'll Need:
* Blackberry Pearl Smartphone
* Bluetooth headset
Turn on your Bluetooth headset by pressing and holding the multifunction button.
Check if the LED light is a solid blue. Turn off the headset and repeat the first step if the light is blinking.
Activate the Bluetooth wireless connection on your BlackBerry Pearl by Going into your "Settings" menu
Select the "Options" menu to go to your connectivity settings
Click on the "Bluetooth" option to activate the connection
Choose the "Add Device" option on your BlackBerry Pearl to locate the headset
Wait for a while as your Smartphone locates the Bluetooth headset
Enter 0000 for the password after selecting the headset to complete the Bluetooth pairing process
After that, your Done !!!!you can now send and receive. But after following this instruction and no solution yet, that means there is something wrong with your blue tooth. Corrupted. You will need to reset the phone.
MY BLACKBERRY 8120 CAN'T CONNECT
I had the same problem with my BlackBerry Storm. How did i fix it?Connect the phone to the pc or laptop the follow the below steps:1. Go to Device Manager and select the BlackBerry option from the list of hardwares displayed.2. Right click on it and select the update driver software option.3. Select the browse my computer for driver software to manually locate the folder with the driver for you device: i.e C:\Program Files\Common Files\Research In Motion\USB Drivers.4. Click ok and start the desktop manager software if it works if it doesn't, reboot the computer and try again.Hope it works for you like it did for me.Cheers
Network MEP code
the network code will be at the home or office on the wireless network roter
please rate my help
thank you
I m not able to
Are you able to hear calls if you put the phone on speaker?
You can try turning off your phone, taking out the battery, putting it back in and then powering on again.
You should also try contacting your carrier- this could be an issue with their service, not your phone.
I can't make calls directly
Hi , I think to make local calls you will have to add +91+ mobile no eg: 91XXXXXXXXXX
in front of the mobile no. In order to make a call to land line you will have to add the city code + land line no . eg: If you want to call Hyderabad , the no will be like 040XXXXXXXX . To make a call to mobile no in other city add 0 in front of the mobile no eg : 0XXXXXXXXXX .
PICTURE COMING OUT BLANK
dear friend,
this mainly occurs due to software problem,so for that you have to visit the service center
enjoy & cheers
My bluetooth not responding
to recieve anything via bluetooth on blackberry phones you must first choose the file of type..eg.if you want to recieve a picture from someone, go to media-pictures-blackberry button-recieve file. To send you must be paired and have it switched on perm.
Blackberry 8120 bluetooth
First off, did you pair with the phone? Open up your bluetooth menu (under settings) and search for the other phone. After you pair (the passkey is what you choose each time) you'll be able to receive bluetooth connections.
To receive files over bluetooth, you'll need to open up your media area, click the blackberry button, and scroll down to "Receive using bluetooth". At that point, send the file using the other phone and enjoy!
How to unlock my blackberry 8120
Hello, there is no software or unlocker available for this mode, you can get an unlock code from internet for your blackberry 8120.
Once unlocked you will be able to use your BB with any carrier (GSM) of your choice worldwide.
You can get your unlock code from
here.
Code comes via email and with step by step instructions. Total process is hardly 30 seconds long once you have the unlock code.
Hope this is helpful.
When I try sending a text message a red x appears
First of all, make sure that you have service and that your service includes text messaging. If you have all of the above, without powering off your phone, take the back of your phone off and take the battery out. Leave it out for a minute or so and place it back in. Replace the back of your phone. Power it back on. Retry sending messages. I hope this helps.
