20 Most Recent
Dell Vostro 1000 Notebook Questions & Answers
Dvd player problems
When you put the DVD in the player, are you snapping it onto the spindle? You have to do that with notebook PCs, but not with desktops.
Password lock is on, don't know it and want to factory reset it
If the password lock is on the machine rather than just windows you will have to disassemble the machine, removing the keyboard and the top cover then removing the motherboard battery for five minutes and then reassembling. If the password is on windows alone you will be able to access that through the use of cracking software.
http://supportfordell.iyogi.com/vostro/restore.html
Vostro 1000
if your tv supports vga port connect using vga cord and use the combination keys fn and f5 or whichever specified second option ids hdmi or video out.
Vostro 1000 Fn locked
This is ****. Respondent doesn't know the model in question and his suggestion is of no help--there is no "blue lock" graphic imprinted anywhere on the Vostro 1000 keyboard. A user with this sort of question is already frustrated and does not need his desperation exacerbated by a nonsensical response from someone calling himself "RescueTech".
The user, on the other hand, may be excused for believing the problem is a locked Fn key--Dell does you no favours by printing the alternate number labelling in blue, AND the problem is reversed as long as the Fn key is held down--but the actual culprit is Num Lk. You'll find it on the top-most row, five keys from the upper-right-hand corner. Press it once and your problem will vanish.
Change french to english
when restarting ur computer before the windows display try to press the f9 or f10 key depending on your own system..you will find the system configuration there and then click on language to change to ur desired language..but if you were unable to see the english languauge option, then you have to install a new operating system to it..simply because it was installed with a french OS...
How to reset Dell Vostro
hello sir... i can help you..
send me your service tag wich u can see on bottom .. or when you turn on your system you will see a hash code.. like this #1234567-595b send me that one i will send you master password
Thanks
No power
maybe you have already done this, but remember that many laptops require that you remove the battery for about 30 sec. as well as disconnect the AC power to reset them.Always try this when everything seems completely dead.
