20 Most Recent
HP 2133 Mini-Note Notebook Questions & Answers
Wireless connection wont pick up networks with mint 14.1
What wireless adapter do you have ? Broadcom, Atheros, etc ? I also had some trouble installing Broadcom on my Compaq nx6325 on Ubuntu but Ubuntu has some good support sites... Here is an example for Mint for Broadcom drivers ...http://community.linuxmint.com/tutorial/view/379
4/18/2013 9:01:39 AM •
HP 2133...
Answered
on Apr 18, 2013
Hp mini is locked up
If you do a google seardch you can find software that will allow you to reset the password Go to the link I have provided and download the software to reset your pass wordhttp://www.petri.co.il/forgot_administrator_password.htm
10/19/2011 1:52:02 PM •
HP 2133...
Answered
on Oct 19, 2011
How di i unlock my
Hi yenim
- first a fall u check a small button in mouse pad bottom right hand side .
- whether it will lock or unlock.
- it indicates above whether the button is lock or not
- if it is locked then press it again,it will release
- then u have to work without scroll the side bar....
12/23/2010 4:47:47 PM •
HP 2133...
Answered
on Dec 23, 2010
My hp mini touch pad doesnt work - help!
Hi! try to check if there is on/off button for touchpad, normally there is a touchpad indicator light that you can check if it is on or not. If this doesnt work, use an external mouse and then try to uninstall and reinstall the driver of your touchpad in device manager:for xp:start->right click on my computer->properties->hardware->device manager->mice and other pointing devices. Uninstall it and then reinstall the driver. you can download the touchpad driver from the hp support website(support.hp.com) if its missing. Hope this will help...Cheers!!!
5/18/2010 7:50:22 PM •
HP 2133...
Answered
on May 18, 2010
Do i need to disconnect charger for a factory restore?
NO , never,
if the big laptop , is old NONE TOLD, and that huge battery is bad as most are old, I'd remove it and run on only the AC/DC power pack
alone.
laptops PCs have to have bad huge batteries even 1 year old abused.
charger = AC/DC POWER PACK.
The charger is actually deep inside the PC> (a chip by same name)
no PC told but if you read the manual ,chapter recover, sure
it many leave out details, they assume the PC is 100% hardware prefect and is only a dream of data only geeks.
5/2/2022 11:54:23 AM •
HP Mini...
Answered
on May 02, 2022
How do we find out how to get our login information so that we can log on to the internet?
what a great question and so clear !!
well there are only 2 ways. (safe)
1: call your ISP and ask them. if they
own the router ask them.
some IPS put sticker tag bottom? of PC with credentials.
2: if however the router is
owned by you, the answer is inside YOUR router, and is covered in your Router manual, by exact model #
the 3 things to set are
- SSID (broadcasted name) I use dogs name use a name only you know so when seeing 50 others in the hood you know right away that REX123 is you.
- set encryption to WPA2
- SET WIKI PASS PHRASE TO WHAT YOU WANT, and is case sensitive...
- never use AD HOC mode or open wifi if seen.
- nor WEP
- nor WPS or PIN.
go to makers web site if router is netgear go there. get your free manual and keep it PDF.on your PC.
then read settings page.
5/1/2022 2:55:21 PM •
HP Mini...
Answered
on May 01, 2022
Vox mini laptap reset factory
hp.com
tell them pc model full, you did not.
find manual there
read it
chapter RECOVERY.
if lost ask on there forum hp.com
1/14/2022 9:59:29 PM •
HP Mini...
Answered
on Jan 14, 2022
Hp mini 210-1170nr
check that the ribbon it may have come back out or its not put back right.
check the wires on the inverter and make sure all wires and ribbons are all in place.
4/14/2015 6:33:39 PM •
HP Mini...
Answered
on Apr 14, 2015
How can i download free video to my mini hp laptop
Download Chrome web browser and FVD Downloader software. Install them on your HP laptop. Then click the icon at left upper corner of the browser window while the free video is playing. Out of the listed media, you can select the media to be downloaded.
1/6/2015 11:21:03 AM •
HP Mini...
Answered
on Jan 06, 2015
