Question about Homelite Curved Shaft Trimmer Bump Feed Replacement Line
Which way should the line be fed clock or counter clockwise. Spins clockwise.
I,m no expert but you could try feeding it the oppisite way it spins. so i would say counter clockwise. if not it,s 50/50 it must be the other way
Posted on Jun 28, 2011
Chopper spins clockwise . How do I fix it
It is spinning around because one of the rotors is not spinning at full speed. This happens when you bump a spinning rotor against something. Determine which one it is by observation or logic (i.e, the one that turns clockwise will produce counterclockwise torque, which is to be balanced by the other rotor spinning counter clockwise. So the counter clockwise spinning rotor is slow) Tighten the screw that holds that rotor that is spinning more slowly. Use the screwdriver that came with the spare parts.
Dec 15, 2011 | JCPenney Gyropter RC Helicopter
I am working on my 82 xj 750 maxim...... i have done a top end rebuild but want to make sure before i start it up that the enging turns counter clock wise because turning it clockwise.....it wont turn the...
looking from the left side, the crank spins counter clockwise.
I'm intrigued how you would turn it backwards, if you touch the starter or kick start, it is going to go the correct way. If the tensioner is working it shouldnt slip anyway
Aug 25, 2011 | 1982 Yamaha XJ 650
Have honda civic 1991, how does the bolt on the crank shaft belt pully turn? counter clock or clockwise?
its a regular right hand thread so counter clockwise to remove, clockwise to install.
They can be a real bear to get off. An impact wrench is usually required.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 28, 2011 | 1991 Honda Civic
I purchased a Wilton 6 in grinder, model 17203. It spins in a counter clockwise direction. Is this normal? In other words the wheel is turning down on the material being worked. Thanks Jim Price
Counter-clockwise as viewed from which end? The correct direction as viewed from the right end would be counter-clockwise. As viewed from the left end it would be clockwise. In other words, when using the grinder from the front, the surface of both wheels should be going down. If this is not the direction it turns, take it back. Good luck, Al K
Feb 02, 2011 | Wilton 17202 8" Bench Grinder
On adjusting headlight on 08 tundra does clockwise
clock wise should pull light up. counter clock wise should tilt down
Mar 07, 2010 | 2008 Toyota Tundra
Dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Jan 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
184 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
