I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the motor appears to run but No agitation?? The belts are fine and the rinse & spin cycles work fine... What am I missing?
    Problem Solver:
  • 5 Answers
If this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Posted on Jun 09, 2011
SOURCE:
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
My maytag quite series 100 _ fills with water starts running cycle but stops after about 20 sec _ it does this 3 times then shuts completely off
Sounds like the timer could be a issue . or motor running to hot clean all under and behind make sure no dust ..UNPLUG UNIT FIRST ,....
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Sep 28, 2015 | Maytag Washing Machines
Maytag dependable care LAT8435AAE fills with water then quit. Has power but will not start in any cycle
You need a new timer. It's an easy repair ...
http://www.repairclinic.com/Maytag-Washing-Machine-Model-LAT8435AAE-ID-90821-Circuit-Board-Timer-Parts
Jul 19, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
Maytag A412 series 11 just overflowed water everywhere.
This is caused by a faulty water level switch. It is a diaphragm-like device that has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to turn off the water and signals the timer to start the appropriate cycle. Check for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Hope this helped and best wishes.
Aug 29, 2009 | Washing Machines
Will not start wash cycle
Sound like the lid switch has went out , you should hear it click when the lid is close to an inch of being closed , they are un-expensive and easy to replace and they go out often from use. Easy to find online with your real model number located under the lid.
Phil
The washer with the grind noise is a main bearing going out and may be covered under warr. through maytag.
Apr 11, 2009 | Maytag Atlantis MAV7000
Maytag Washer Legacy series When cycle starts the cold water just trickles in and takes a long, long time to fill. The faucet valve is fully open. When I unscrew the hose from the machine and turn the...
Remove the cold hose from the machine.
Look inside the inlet you removed the hose from, there will be a screen.
Take it out, clean it, and replace it.
Problem solved.
Feb 22, 2009 | Maytag Washing Machines
Washing Machines Logo
495 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
