Question about Whirlpool Washing Machines
Front load drive motor on Kenmore washer will only turn the drum in a counter clockwise direction an there is no fast spin
  • 958 Answers
You could have choosen the gentle care mode or delicate mode where in it would only run in one direction and would spin slowly.
tnx 4 using fixya,
drcool
Posted on Jul 28, 2008
My washer will not spin and acts like the inner drum with holes is stuck, what is wrong?
One of two reasons: The drum belt has broken and needs replacement, or TWO, check for an object that may have accidently jammed the drum from turning; such as a sock falling into the tract where the drum rotates, or a bad seal. Check the drum for movement by hand, and see if you can free it up manually. Last: check alignment. Look for damaged fittings.
Feb 04, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
The washer loads water and pumps it out like normal, but it does not spin. It goes through the cycle but with no spinning of the drum. Why dose it not spin?
broken belt on drum drive motor? bad motor on drum? bad connection on motor? if you remove the oval panel on the back you can see the motor, belt and drum assembly
Feb 12, 2011 | Kenmore Front Load Washer
My Kenmore Elite HE 3 model #110 4822 201 will not spin. It runs through an entire cycle and fills and drains. The drum will turn a few turns clockwise when spun by hand but then will not move further...
Hello there:
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool and Kenmore have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jan 15, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
My washing machine won't spin. I check the motor
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool / Kenmore PDF on operation and maintenance of their top load, direct drive washers.
It has a good description of how the transmission works.
Following is the Whirlpool parts diagram for their commercial top load, direct drive washers including transmission parts and numbers. The parts for the consumer washers are basically the same.
We assume that something broke the coupler the first time.
I'd check to make sure that when you put the new coupler in, the six holes in the rubber piece lined up with the prongs in the plastic pieces.
If they did, the next thing to check is the transmission.
Following is a description of how to pull the transmission / gearcase.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
I found that instead of buying a special spanner wrench to remove the Tub Nut, a 10" pipe wrench opened fully and hooked to one of the prongs on the Tub Nut, giving it a quick tap with a hammer does well.
You really don't have to remove the drum and Tub Nut and drive block to remove the transission.
I'd pull the transmission and try turning the input shaft manually both ways, clockwise and counter-clockwise.
If it won't turn, it's likely that something in the transmission has broken and is jamming the main drive shaft.
There are a couple of plastic parts in the transmission. The Agitate Cams and the gear teeth on the main spin gear.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 16Oz of oil, remove the clip holding the main spin gear on and check the plastic agitator cams and the main spin gear.
The main spin gear is relatively expensive (Approx.$90 ) so if that is broken, you might want to consider a replacement transmission.
The Agitator Cams are only about $15,
Oct 03, 2009 | Kenmore 24902 Top Load Washer
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Mar 24, 2008 | Bosch WFLI 2440 Front Load Washer
Kenmore elite 44832 front load washer troubleshooting F11 c01 c02
Was there ever a post back for this problem? I have the same issue, and I tried replacing the central control board, but it is still giving the F11 error. I follow the troubleshooting guidelines, but it never makes it past C01. I suppose the next logical step is to look at the motor control board and then the motor.
Sep 11, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
126 people viewed this question
Sal De
Marvin
Marvin
jimorris77
