Question about Whirlpool Dryers
Which way does a whirlpool dryer spin? clockwise or counter clockwise?
    Sniper:
  • 107 Answers
They Spin Clockwise.
Posted on Dec 01, 2009
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
How to remove the motor pulley
clockwise releases and counter clockwise tightens
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
May 14, 2014 | Whirlpool Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
DRUM WILL NOT SPIN, BELT IS OK
have you try to rotate the drum when belt is attached or installed, unplug your machine and try to spin it manualy at the back opening where you can access the mechanical part
try to use the belt when turning it counter-clockwise see if it will turn the drum, if not then the fproblem is the bearing
Nov 08, 2009 | Whirlpool LGR6611L Gas Dryer
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Whirlpool dryer not exhausting air, and the drum is spinning counter-clock wise
The first and most important thing you need to do, is to disconnect the dryer from the wall outlet before doing any kind of work on it. Most parts will need to be checked for continuity and the dryer must be disconnected from the wall outlet.
Most of the times the part causing the problem is behind the dryer and you can gain access by removing the back panel.
Aug 22, 2009 | Whirlpool LER4634J Electric Dryer
Dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Jan 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool dryer !
its always recomended that you turn clockwise on a timer that only goes that way but if it moves c/wise or a/clockwise with no effort then it was desighned to do this hope this helps
Jun 15, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirpool gas dryer
HI thanks for the question. the drum must be out. with a right size wrench. hold the blower wheel . from turning . with a 3/4 inch socket. put socket on the motor pulley. turn the socket clock wise . it should loosen. thanks the appliance doc
Apr 13, 2008 | Whirlpool LGV4634JQ Gas Dryer
Aqualux 1200i
did you happen to solve the problem? I am having the same exact issue with mine...washes fine, but won't do the spin cycle. it spins counter clockwise really slow at first, presumably to balance the clothes, and then starts to spin up clockwise (to do the spin cycle) but then whinnies and then stops....!
Oct 14, 2007 | Electrolux EW1200i Front Load Washer /...
Dryers Logo
2,290 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
