Question about Building Materials
Our garage door opener is not working. The person who check it he said the problem is the chip board. Is there possibility to replace the chip board.
    Top Expert:
  • 22,486 Answers
Buy a replacement
Posted on Oct 21, 2019
6ya staff
SOURCE:
marty metzger
  • 244 Answers
SOURCE: garage door circuit board replacement
get instructions and program. I hate Genie
Posted on Jan 15, 2009
Anonymous
  • 318 Answers
SOURCE: Homelink Garage Door Opener works in-consistently on 99 Chrysler
Change the battery in your IN Car remote control.
Posted on Jan 16, 2009
marty metzger
  • 244 Answers
SOURCE: Need Replacement nutone garage door openers
unit must be ancient. try sears for a universal radio control set. if unit is as old as i think, i would toss it and get a new one. you will not be able to get any parts for this unit and it does not have safety beams.
Posted on Jan 28, 2009
marty metzger
  • 244 Answers
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
SOURCE: Just installed a new genie garage door opener.
Change the sensor and make sure the magnet comes close enough to activate it. Sometimes I have even changed the magnetic ones for real switches too.
Posted on Jan 31, 2010
Testimonial: "Thanks for the info. Interesting you mention a magnet. I don't see one unless its built into the carriage."
Garage door opener
Check photo eyes. Shut off power to units and try again
Aug 21, 2016 | Building Materials
GARAGE DOOR OPENER REMOTE ONLY WORKS IN GARAGE WILL NOT WORK IN DRIVE WAY
1st, try replacing the battery in the remote. If that doesn't work, you will need to replace the logic board on the opener, which is typical in the craftsman openers.
Oct 02, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
We have Craftsman garage door openers for both doors on our double car garage. The problem is with our keypad and our remotes in the cars. The keypad and car remotes work fine for one side of the garage,...
It sounds like the logic board has quit working on the one opener. If you have had lightning or power surges you might remove the logic board and check for loose, burnt or missing traces on the printed circuit.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 13953919 door opener. My garage door opens during the day when I am not home. The alarm company calls me to let me know, and the police have been by twice. Nothing is stolen, so I can...
Here are some things to check.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Apr 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
My controls will not open or close my garage door. The wired control works. I read that the logic board is bad. How much is the logic board and how hard is it to install. Is it better to just get another...
A new board is @ $86.00. Because I do not know your skill level I really cannot say whether it is easy or hard to install. I have replaced boards and I find it easy, but my brother would find it impossible. So it is subjective and you know your own skill level better than anyone else. I personally feel that it is not too complicated for a typical homeowner to do. In this economic time, some people have no choice and cannot spend the extra money for a new opener, but again I do not know your financial situation either. So the choice is yours, but if you can use a screwdriver and stand comfortably on a ladder, I would replace the board. I hope this helps and good luck!
Please remember to vote c5e7dfb.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Our remotes do not work when the garage door is closed, but they do work to shut the garage door when it is open. help
There are two possibilities here. One is the remotes batteries are weak and need to be replaced. The other is the receiver is going bad. If new batteries don't increase the range of the remotes then you will need to replace the logic board.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
27 people viewed this question
Top Building Materials Experts
Lawrence Oravetz
Tom Chichester
ray gallant
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
